CRX with B18C5 engine not starting, please help !!!!
ok, heres the story
the car originally had b18c1 turbo engine, i have aftermarket wire-in computer , but still using my stock wiring loom from my b18c1
now i dropped in a jdm b18c R engine, still using my b18c1 wiring loom , i chopped some bits of sensors / plugs from my ITR wiring loom.
everything is plugged in and connected , but there is no ****** power on the computer and injectors !!!!!! the fuel pump is not even running !!!
the engine is cranking but thats about it
please help guys !!!!!
there wont be any code , since the computer has no power at all
the ignition is working , but when i plug-in the hand controller for my aftermarket computer , it just not working
looks like you may have chopped one of the power wires that run the ECM I think those wires also give siginal to fuel pump.
check out your cut and paste maybe put it back to stock way it was before why did you chop it up anyways since you had b18c and b18c5 = same wiring
you said you were running an aftermarket computer umm you should have tired to start it with that same computer.
what model car u have si, dx??
its a JDM EF8 CRX SiR , it originally had a b16a in it.
to be honest im not sure what wiring was used when it had a b18c1 engine in it , since i did not do the conversion, it could be a b16a wiring loom
but either way after i dropped in the b18c R engine in it < complete running engine , distributor , alternator , etc >. I looked my original wiring , and most of them doesnt fit to my ITR engine plugs/sensors
Thats why i chopped some bits and pieces off my ITR wiring loom, and im running my the parts that originally were on my b18c1 engine.
So the car has no power at all or just wont crank over. Check grounds, thermostat ground if just fuel pump isnt kicking on. What about wires going to the underhood fuse box, make sure the tranny ground is good too. Cuttin a sensor wire and resplicing would probly not make your car get any power.
there is NO power on my computer , injectors and fuel pump
the engine cranks , ignition is working fine , i get all the warning lights , but computer is dead
So your getting spark, and if your getting spark and the car still wont start it is a fuel problem. Main relay? blew a fuse ecu does have a fuse. ect...check anythign and everything to do with fuel. Get a wiring diagram and check all of the fuel system wiring.
From: not riding any bandwagons in, massachusetts, usa
so youve got the money for a type R and trust the free advice you get from strangers to work on it?
http://www.helminc.com
do yourself a favor and buy some manuals.
went to my mechanic today
he said everything has been grounded perfectly , the car is has no positive power at all
someone suggested to change my main relay , if i changed to a new one , would the computer be working ??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I See Dead People »</TD></TR><TR><TD CLASS="quote">went to my mechanic today
someone suggested to change my main relay , if i changed to a new one , would the computer be working ?? </TD></TR></TABLE> should work even with the main relay broke
RUNNING TODAY , w@@t !!!!!!!
there was a bunch of loose wires around the thermostat , as soon as my mechanic tightened it up , w@@t got power straight away
thanks guys !!!!!!!
thanks guys !!!!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by I See Dead People »</TD></TR><TR><TD CLASS="quote">RUNNING TODAY , w@@t !!!!!!!
thanks guys !!!!!!!</TD></TR></TABLE>
Yeah very easy to over look, figured thats what it was. glad you got it running
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rice_classic »</TD></TR><TR><TD CLASS="quote">A (running) b18c5 in a crx. GOD I'm jealous!</TD></TR></TABLE>
not a usdm b18c5 , its 97 JDM ITR engine
will post picture when i got it back
Cyber ITR
Nov 22, 2004 06:26 AM
Cyber ITR
Nov 14, 2004 07:48 PM
Cyber ITR
Nov 14, 2004 07:24 PM
