VTEC Problem Plz HELP!!!
Old Nov 11, 2004 | 02:48 PM
hitvtecgetloud09's Avatar
Default VTEC Problem Plz HELP!!!
my 99 boosted si is giving me these 3 codes
P1298 Electric Load Detector (ELD) Circuit High Voltage
P0135 Primary Heated Oxygen Sensor (Primary HO2S) (Sensor 1) Heater Circuit Malfunction
P0141 Secondary Heated Oxygen Sensor (Secondary HO2S) (Sensor 2) Heater Circuit Malfunction
My speedometer does not work nor my turbo timer, alot my vtec will not work, i replaced both o2 sensors and a new alternator wat else can be rong??
Old Nov 11, 2004 | 04:23 PM
86si's Avatar
Default Re: VTEC Problem Plz HELP!!! (hitvtecgetloud09)
check the alternator/VSS fuse in the underdash fuse box i've seen this fuse blown many times and it will throw those codes and the speedo won't work also the alternator won't charge
Old Nov 11, 2004 | 04:37 PM
Default Re: VTEC Problem Plz HELP!!! (86si)
which fuse is this does it look like a normal fuse? or is it a diff. looking fuse?
Old Nov 11, 2004 | 05:01 PM
86si's Avatar
its a 7.5amp fuse look on the fuse cover it will say alternator/vss and the # of the fuse
Old Nov 11, 2004 | 05:17 PM
thanks guys im so ****** pissed i just spent 250 bucks on the alternator and 2 o2 sensors cuz my ****** ecu was givin me those codes and it ends up being a ****** 10 cent fuse OWNED!!!
Old Nov 12, 2004 | 02:42 AM
86si's Avatar
sorry to hear it bro,always start with the basics when trying to diagnose
RVMIRXZem1
Oct 26, 2018 07:05 PM
Civic Racer X 7
13
Jun 1, 2011 04:56 AM
iKhmaiFoSho
Jan 6, 2006 01:56 PM
LOWLIFEHATCH
Apr 24, 2005 11:37 AM
turbod16y8
10
Dec 30, 2002 06:06 PM
