coilover question
In most cases you do not need the spring compressor when installing coilover sleeves on struts. You can lower the perch enough to be able to put the top hat on. However, removing the old spring from the strut will require a compressor. You can take the spring off without the compressor, but it is dangerous and not recommended.
Beach Accord
Oct 18, 2004 03:09 PM
All_JDM_Si
Sep 29, 2003 11:00 PM
