turbo installed but not getting boost
Old Nov 11, 2004 | 11:10 AM
jeffsciv23's Avatar
Default turbo installed but not getting boost
i have a 99 ex coupe and i installed my turbo kit a few days ago but haven't seemed to be able to see any boost. i have checked the wastegate and hooked it up to the IM to see if that would help. checked pipes for leaks a few times but can't find any, car keeps throwing codes 71,72,73, and 74 (misfire on all cylinders) so i keep adjusting the timing but once i get into the throttle good it throws it again. what could the problem be? oh and before i got my downpipe on i could hear the turbo spool like crazy, now i can't hear it at all. could my turbo need a rebuild?
my set up is:
tubular manifold
saab T3 turbo
internal wastegate
CCA 6" FMIC
Greddy type s bov
2 1/2" charge pipes
dsm 450's
V-AFC
2 1/2" exhaust
timing set at stock (well thats what i set it at).
boost and A/F guages.
Old Nov 11, 2004 | 11:17 AM
aznballer's Avatar
check and recheck everything, maybe ur wastegate sees no signal for boost
Old Nov 12, 2004 | 07:31 AM
jeffsciv23's Avatar
Default Re: (aznballer)
i'm gonna change my timing belt today to see if that helps.
Old Nov 12, 2004 | 07:39 AM
boostjunkie757's Avatar
how is changing the timing belt going to help?
Old Nov 12, 2004 | 01:17 PM
95hatch's Avatar
Default Re: (boostjunkie757)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostjunkie757 &raquo;</TD></TR><TR><TD CLASS="quote">how is changing the timing belt going to help?</TD></TR></TABLE>
Duhhhhh dude the timing belt spins the turbo. Dont you know anything.
Old Nov 12, 2004 | 01:47 PM
jdm.ej's Avatar
Default Re: turbo installed but not getting boost (jeffsciv23)
might be that your running 2 1/2 piping. takes longer for spool time.personaly i think that 2.5 is kinda big for y8 stock.thats just my .02
Old Nov 12, 2004 | 01:51 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo installed but not getting boost (jdm.ej)
ok, a turbo that small wont make that much "spool" noise. its all dependent on the size of the turbine housing, which isnt that big in your case. also, do you have a missing link to keep the ecu from seeing boost?
Old Nov 12, 2004 | 02:32 PM
RACEPAK's Avatar
Default Re: turbo installed but not getting boost (wantboost)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">ok, a turbo that small wont make that much "spool" noise. its all dependent on the size of the turbine housing, which isnt that big in your case. also, do you have a missing link to keep the ecu from seeing boost? </TD></TR></TABLE>
i dont think that you need the missing link with the V-afc hack.
Old Nov 12, 2004 | 02:35 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo installed but not getting boost (RACEPAK)
yea u do, at least thats how i remember it, the afc doesnt keep the ecu from seeing boost, only a change of fuel values for a given rpm.
Old Nov 12, 2004 | 03:19 PM
tspkenneth's Avatar
i dont you need any missing link either..when you switched the wastegate line to the intake manifold did you plug up the hole on the turbo? other than that check all your pipings..
Old Nov 12, 2004 | 05:45 PM
jeffsciv23's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wantboost &raquo;</TD></TR><TR><TD CLASS="quote">yea u do, at least thats how i remember it, the afc doesnt keep the ecu from seeing boost, only a change of fuel values for a given rpm.</TD></TR></TABLE>
you my friend are a jackass.
i had a t-25 on before (smaller turbo) spooled loud as hell. and when using the hack you don't need a missing link, (thats basic turbo knowledge maybe you should not try and give advise in the FI forum?).
no i didn't plug the hole i hooked it p to the lower nipple on my type s. tomorrow i will probly take all the piping off and check it for leaks more closely but i have checked a couple of times now so i am pretty sure the turbo is leaking from the compressor housing. i changed my plugs and wires today and nothign changed. so i don't think i'm gonna change the timing bellt until i get the boost problem fixxed.
Old Nov 12, 2004 | 05:57 PM
scartail's Avatar
could the missing link itself cause prevention of boost? the orings, if you have these fancy-looking type?
I'm in the same boat... different setup... no boost...
Could you tell me what happens? Since the guys are saying you don't need the missing link with the hack, you would be removing the missing link.
Old Nov 12, 2004 | 07:43 PM
wantboost's Avatar
Who is Mr Robot?
Default Re: turbo installed but not getting boost (scartail)
sorry, im not exactly vafc literate. does your t3 have a bolt on outlet flange or is it just the straight outlet? i would check that first.
Old Nov 13, 2004 | 03:29 PM
8herout's Avatar
same problem somebody help
Old Nov 13, 2004 | 03:34 PM
1boostedcivic's Avatar
Default Re: turbo installed but not getting boost (beat-her)
check for boost leaks, vacuum hookups, wastegate arm, and make sure ur vafc is set right. in 6 out 6, 40 across the board.
Old Nov 13, 2004 | 10:46 PM
PrettyLude's Avatar
check all ur piping connections
Old Nov 14, 2004 | 06:43 AM
turboimports's Avatar
Check you vacuum lines, hoses, piping, check for manifold leak, check for oil pressure, check wastegate.
-Lor
Mikato Soul
Jun 7, 2008 05:51 PM
RFd15bhatch
May 24, 2005 12:27 PM
MooreBoost
Aug 8, 2004 11:14 AM
racinskittle
Jul 18, 2003 08:53 PM
Cyber ITR
Dec 9, 2001 01:51 AM
