Mini Me
I am going to buy a d16z6 for $200. But it was out of an Automatic so it wont be coming with tranny or ecu. The person says he dosent know how many miles are on. So should i buy it, what should i look for? What computer should i try to buy and anything else that would help.
I'd buy it. Just use a 88-91 civic/crx si ecu, distributor and injectors. Then hook up a external switch or a vtec controller for the vtec. You can't use a hydro tranny in a EF anyways, so get a 89-91 si tranny and you'll be set.
Is your car a si or dx?
My car is a dx. So should i use all the z6 parts or try to find si parts such as ecu manifold, injectors and so on. What links do you have marked001. I want to make this easy but i also want the most power i can get out of these combination.
[Modified by Hayasa15, 11:59 AM 12/26/2001]
get it, this is a good deal if the thing works. when i bought my z6 head only, i paid 225. u can probably sell the block just for that money and have the head for free
dont forget, when u put the head on the stock CRX block it's not the same as the whole d16z6 engine. this will give u 10.5+ compression and u'll make more hp.
this page is if you're using the p28 ecu...(obd1)
http://www.geocities.com/kurtsi_on/page7.html
these are all using si components... not the best way, but cheap and easy...
http://www.geocities.com/crx288/d16z6swap.html
http://www.geocities.com/motorcity/s...15/4gtech.html
http://www.angelfire.com/ca/DrOhm/hybrid.html
Just FYI, even if your sticking with the non-obd setup you can still use the z6 intake manifold and all the sensors. All you'll need is non-obd injectors from an si, and of course an si distributor and ecu.
since you've got a dx, you're gonna have to spend some more $$ anyway...may as well go the right way, you're gonna end up paying the same amount either way probably. you're gonna need a si dizzy, pm6 ecu (88-91 si), rpm activated switch, plus other miscellaneous... figure at least $200 for that stuff... to do it the right way, you're gonna need a p28 ecu and OBD0-OBD1 harness figure around 4250...all providing your engine is complete w/ injectors and distrbibutor...you're gonna end up spending only a little bit more for an engine that runs better and stronger....
Marked i also want to know if with the z6 swap can i reuse my accel plug wires or i have seen some people say you need to use z6 plug wires. Also do you know anyone that has a P28 for sale, reasonably priced?
...gotta use the z6 wires. keep a look out on http://www.thepartstrader.com ...you should be able to get one for $100-125..I wouldnt pay anymore.
superhatchbackbros
Feb 7, 2006 07:07 AM
hondafrk
Jul 23, 2002 01:54 AM
