Hazzards not working after fixing wiring disaster from dash swap
I fixed the wiring in my EG after Teg dash conversion and now the hazzard switch does not work. The turn signals work, illumination on the switch still works, the switch itself is still good (tried it in my integra), and the signal relay (under dash) is still good because I swapped and tested it (from integra).
What am I missing here? Under hood fuse ? I don't have the cover for the fuse block so i don't know what is for what under there.
Need to get this fixed so I can certify the car and get it on the road.
Help Please
Help Please
use the search engine lol https://honda-tech.com/zerothread?id=1011091 j/k
told you there was a fuse under the hood.......
CRXsiproject
Oct 19, 2005 12:15 AM
ShakesTheKlown
Oct 8, 2002 07:09 AM
