MUGEN air cleaner box for DC2 with A/C system
Hello everybody
I am a french new member, so I would like to apologise for my bad english first :-)
I bouhgt one month ago the MUGEn Air cleaner bow for ITR DC2, but thing that I did not know, is it does not fit in DC2 with air conditionning system !!!
Has anybody tried to remove the 2 tubes under the box, or changed them ?
The best solution would be to remove the entire system but I want to avoid this...
I need some HELPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPPP
Thanks guys for your kind understanding
J.
J.
I believe you have to spread the 2 ac lines apart to fit it in... there are some posts around here if you search.
Most also contain pictures as well. I hope this helps.
Welcome to the board
This thread should be quite helpful to you
https://honda-tech.com/zerothread?id=376228
yes splitting those two tubes apart is going to be a pain, but make sure you dont bend it too far where you damage your ac lines. Also you might want to be sure when you set the ac lines apart that it isn't rubbing on anything. welcome to the board...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadking74 »</TD></TR><TR><TD CLASS="quote">Hello everybody
J.</TD></TR></TABLE>
Hi, thats me!
Hi, thats me!
Thanks guys, it helps a lot....
I'll try to contact KKIM directly, do you know if he's still a member of the forum ?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roadking74 »</TD></TR><TR><TD CLASS="quote">Thanks guys, it helps a lot....
I'll try to contact KKIM directly, do you know if he's still a member of the forum ?</TD></TR></TABLE>
He's still a member, but doesn't seem to frequent the board as often as he used to.
Modified by Mugen Mike at 10:59 AM 11/11/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 »</TD></TR><TR><TD CLASS="quote">yes splitting those two tubes apart is going to be a pain</TD></TR></TABLE>
It's easy. I did it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote">but make sure you dont bend it too far where you damage your ac lines.</TD></TR></TABLE>
You don't really bend. You just zip tie one to the leftmost primary of the header, and the other to the SRS mount. Then you put the Mugen Intake in, put some double sided tape or something to prevent the A/C lines/bolts from rubbing on the intake, and viola, you are done.
You really don't have to 'bend', just force them out of the way for a short period of time, they'll adjust to their new positions without much trouble.
Also you might want to be sure when you set the ac lines apart that it isn't rubbing on anything. welcome to the board...</TD></TR></TABLE>
Good point. I mentioned that above. You have three areas to be concerned with: one where each A/C line will push/rub/sit on the intake (so that's 2 so far), and one where the wiring harness plug is for the SRS. It sits awfully close to the airbox top. Double sided tape would work best for this, or wrap the A/C lines with a towel or something like that.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kicker773 »</TD></TR><TR><TD CLASS="quote">he should.. but its probably best if you e-mail him just in case he doesn't go on h-t </TD></TR></TABLE>
He's online now.
He's online now.
I'm glad somebody had posted this question. i was going to ask the same thing. hopefuly i'll get mine soon. welcome to H-T btw
thank U all for your advices, I'll follow KKIM's "step by step" mounting explanations and will advise U about results of mouting....
Del Sol SiR
30
Jan 12, 2004 05:03 AM
I'll post pics of my Mugen intake going in and A/C coming out.
