DC2 Mugen Air Box & cleaner into my Mugen Del Sol project w/AC, question ?
I'm trying to make the decision of either bending my AC lines to fit this air box, which is tough and the risk of snapping the lines are high or just yanking out the whole AC system, any suggestions ?
400 HP Club
Re: DC2 Mugen Air Box & cleaner into my Mugen Del Sol project w/AC, question ? (DelSolSiR)
fast cars don't need a/c.... I yanked mine out a long time ago. Just pull it out..
400 HP Club
Re: (b00st)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b00st »</TD></TR><TR><TD CLASS="quote">i've been wanting to take my a/c out...but just don't know how..lol </TD></TR></TABLE> it's easy, take it to a place that services a/c so they can dispense of the freon, take the belt off, unbolt the unit from your block, pull the lines and condenser out from the rad support and bang done and done....
Guest
Posts: n/a
Re: (The good Dohc-tor)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The good Dohc-tor »</TD></TR><TR><TD CLASS="quote"> it's easy, take it to a place that services a/c so they can dispense of the freon, take the belt off, unbolt the unit from your block, pull the lines and condenser out from the rad support and bang done and done.... </TD></TR></TABLE>
or just take off the caps and spray it out yourself then do the rest of the steps
Re: (93EH6)
Make sure you don't get rid of the torque mount or your motor will be jumping around like crazy. And to all of you guys without A/C wtf do you do when your windows start to fog up?
There was another guy on here with a DC2 that got the Mugen airbox, and he also had A/C. He managed to get it all hooked up while keeping A/C too. If I remember correctly, he made a long metal bracket, unbolted the A/C lines from their original bracket, moved them out of the way just enough, and then bolted them in place using the custom bracket. Do a search and you should find it. He had pics too.
Re: (xavior66)
I read that, he used zip ties, but the DC2 & EG2 are slightly different when it comes to the AC. I'm goin' now to purge the freon @ a shop... Thanks H-T !
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xavior66 »</TD></TR><TR><TD CLASS="quote">There was another guy on here with a DC2 that got the Mugen airbox, and he also had A/C. He managed to get it all hooked up while keeping A/C too. If I remember correctly, he made a long metal bracket, unbolted the A/C lines from their original bracket, moved them out of the way just enough, and then bolted them in place using the custom bracket. Do a search and you should find it. He had pics too.</TD></TR></TABLE>
when isntalling the mugen box on my car, i slowly pulled the lines apart, youd be surprised how far they will go to make it fit
if you live where its cold most of the year take it out i live in texas i cant make it with out one. 110 degrees isnt fun. Do you have a pic of the box?
400 HP Club
Re: (93EH6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93EH6 »</TD></TR><TR><TD CLASS="quote">
or just take off the caps and spray it out yourself then do the rest of the steps</TD></TR></TABLE> ya you can do it that way but it's a $5000 fine if your caught, plus it's really bad for the environment.
Re: DC2 Mugen Air Box & cleaner into my Mugen Del Sol project w/AC, question ? (jdmb16si)
none of you have attempted to answer his question
tell him to get some rotas too while hes at it
Re: (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton »</TD></TR><TR><TD CLASS="quote">Make sure you don't get rid of the torque mount or your motor will be jumping around like crazy. And to all of you guys without A/C wtf do you do when your windows start to fog up?</TD></TR></TABLE>
Crack a window
Crack a window
Re: (whoDAT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by whoDAT »</TD></TR><TR><TD CLASS="quote">got any pics of this project?</TD></TR></TABLE>
nm, i saw your sig.
nm, i saw your sig.
Re:
No more AC... New problem though... Still can't install the DC2 Mugen Air box due to my radiator and fan shroud being in the way. On my way to the JDM junkyard in SD to get an EG6 stock radiator, I know its slimmer than my Koyo...
Modified by DelSolSiR at 12:50 AM 1/12/2004
And that is the exact problem we ran into on my buddies del Sol with the Mugen N1 spec B16B. The fan was directly in the way, as was the overflow.
The radiator fan is just going to be blowing hot air right onto the intake ducting, defeating the purpose. He ended up just bolting on an AEM until he can figure out what he wants to do.
