***Need Help BAD PLEASEEE***
Old Nov 10, 2004 | 10:36 PM
VRSEXXIN's Avatar
Default ***Need Help BAD PLEASEEE***
ok guys im new here....but heres the deal, my girlfriend bought this 92 civic hatch CX and her brother took the motor out and droppeed a DX motor on it about 3 months ago....so its a CX body and DX motor....anyhow the problem is the car stall really bad like when you try to take off first gear or like for example when you're in the freeway and you down shift it would stall really bad...and other problem is when your in 5th gear and you punch the gas a little bit the check engine light would come on..today i tried cleaning throttle body and checking all the plugs everything seems to be in the right spot......so does anyone would know anything like this or have anyone experienced this before?????????
Old Nov 10, 2004 | 10:55 PM
McNizzle's Avatar
Default Re: ***Need Help BAD PLEASEEE*** (VRSEXXIN)
bump for you
Archidictus's Avatar
Unceasing Measure
Sounds like a distributor problem to me. If you still have the CX dizzy lying around, toss it on there and see if it fixes the problem. Shouldn't take more than about 10 minutes.
Old Nov 10, 2004 | 11:47 PM
VRSEXXIN's Avatar
Default Re: ***Need Help BAD PLEASEEE*** (Archidictus)
ok thanks ill check that out tomorrow......anymore?
Old Nov 11, 2004 | 09:35 AM
VRSEXXIN's Avatar
anymore suggestions?
Old Nov 11, 2004 | 09:37 AM
Jokerluv's Avatar
USING THE DX ECU?
THEN SEAFOAM IT
Old Nov 11, 2004 | 09:38 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Jokerluv)
Change the fuel filter and check to see if your pressure is correct... do you know what code its throwing?
Old Nov 11, 2004 | 09:45 AM
Andres-eh2's Avatar
maybe the clutch is gone?
Old Nov 11, 2004 | 12:33 PM
VRSEXXIN's Avatar
Default Re: (JDM_Ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">maybe the clutch is gone?</TD></TR></TABLE>
its got new clutch but i dont know which code is throwing i havent taking to it the dealer yet
Old Nov 11, 2004 | 12:38 PM
92eh3si's Avatar
Default Re: (VRSEXXIN)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VRSEXXIN &raquo;</TD></TR><TR><TD CLASS="quote">
its got new clutch but i dont know which code is throwing i havent taking to it the dealer yet</TD></TR></TABLE>
jump that harness by the ecu and see what code it's throwing!!
eg6cx
Sep 7, 2012 06:15 AM
aznfoboi25
May 14, 2006 11:45 AM
vi3t_dude
33
Feb 20, 2005 12:14 PM
civicrtype
Apr 17, 2003 04:47 PM
hybrid_KJ
Aug 9, 2001 07:54 AM
