timing belt came loose?
Old Nov 10, 2004 | 04:22 PM
this name is gone's Avatar
Default timing belt came loose?
ok well i have a vibration and asked my friend aboutit he says it could be the timing belt? what are signs of a timing belt going bad?
-Kyle
Old Nov 10, 2004 | 08:23 PM
PrettyLude's Avatar
check the tension on the timing belt, and inspect it for cracks
Old Nov 11, 2004 | 08:39 AM
Default Re: (PrettyLude)
when i take the valve cover off do i have to replace the gasket? should i anyway even if i dont have to?
-Kyle
Old Nov 11, 2004 | 08:43 AM
mmuller's Avatar
Mad Scientist
Default Re: timing belt came loose? (BseriesCrx)
the car is vibrating?
a timing belt wont cause the engine to vibrate, unless of course it skipped a tooth
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BseriesCrx &raquo;</TD></TR><TR><TD CLASS="quote">when i take the valve cover off do i have to replace the gasket? should i anyway even if i dont have to?
-Kyle</TD></TR></TABLE>
yeah, replace it dont be cheap
Old Nov 11, 2004 | 10:02 AM
Default Re: timing belt came loose? (mmuller)
ok i will go into gr8 detail now. it all started with a little noise from the crank pully at idle. not big i didnt think. then after about acouple days i felt alittle vibration but thou8ght it was just thye road. then after days it got worse and now its big so the vibration just keeps getting worse. tahts about it
-Kyle
Old Nov 11, 2004 | 10:16 AM
draw's Avatar
dont replace the valve cover gasket
Old Nov 13, 2004 | 10:45 AM
Default Re: timing belt came loose? (draw)
the vibration just stopped. is that good or bad. it comes back everyonce and a while but not near as bad. did i break sumthin or did it just fix itself?
-Kyle
doostin
Feb 1, 2009 04:45 PM
ShinobiLude
Feb 15, 2007 09:03 AM
greddytointegrate
Oct 15, 2005 06:05 PM
xingyun
12
Mar 22, 2005 06:35 AM
smkngsr
Jun 30, 2002 08:53 PM
