*****92 integra idle surging*****
Old Nov 10, 2004 | 02:04 PM
benhatch101's Avatar
Default *****92 integra idle surging*****
if my IACV or TBS sensor(s) were bad, would i be throwing a code? i have no CEL now, but my idle surges. im thinking it may just be a vacuum leak....but just wanna make sure its not the sensors 1st
thanks guys!!!!
ben
Old Nov 10, 2004 | 02:05 PM
Default Re: *****92 integra idle surging***** (benhatch101)
hahaha i didnt mean to click on "new poll" sry
Old Nov 10, 2004 | 04:49 PM
ProJectCvic's Avatar
you will be throwing a code if is was bad....surging idle...there is a big chance that you are leaking air.
Old Nov 10, 2004 | 04:56 PM
blusmke's Avatar
go get a can of starting fluid and spray it on your vaccume hoses. Then you will know were the leak is. I had the same problem it was my intake manifold gasket.
Old Nov 10, 2004 | 05:29 PM
DOHC-ter AMIEL's Avatar
Default Re: *****92 integra idle surging***** (blusmke)
your TPS (throttle positioning sensor) could be getting low voltage. thats whats happened to me and my check engne light would light up or not at all. my idle would dip down as low as 100 rpm and it would sound as if it was gonna die put. i believe pepboys told me it was throwing a code 7 i can check the reciept if you want just lemme know
Old Nov 11, 2004 | 09:54 PM
yeegsr's Avatar
what is the change of TB gasket is leaking
i.
49
Feb 17, 2014 12:53 PM
c0nspire
Feb 23, 2006 02:09 PM
limpy
May 13, 2005 09:00 PM
diluted
Jan 21, 2005 10:35 AM
B18C-RnVA
Jul 6, 2002 10:17 AM
