Boston FX6-H or JL VR600-CSi or ???
Old Nov 10, 2004 | 10:40 AM
kgoroway's Avatar
Default Boston FX6-H or JL VR600-CSi or ???
Okay, I've done way too much searching and reading about front speakers for my 98 accord.
I've decided that I want to do as little work as possible. Mostly because I don't have the time/inclination/tools. So, I'm settling for speakers that just drop in.
The Boston FX6-H is advertised as dropping right in... It's a standard coax.
The JL VR600-CSi is advertised as dropping right in... It's a component set that will require extra work to mount the x-over/tweeter, and run wires.
Unless someone can tell me about some specific models that drop right in without doing any modifications other than cutting the stock basket, these are my choices. I was very close to ordering the Phoenix Gold Octane-R 6.0 components, but I don't know if they will fit, and similarly, I considered the Phoenix Gold R6.0 Coax.
Can anyone help me decide between the two I've narrowed it down to, or give me specific examples of models that drop right in?
Thanks.
-Kevin
Old Nov 10, 2004 | 12:11 PM
sopiwnykg's Avatar
Default Re: Boston FX6-H or JL VR600-CSi or ??? (kgoroway)
Go with Boston. Awesome speakers. Way better made than the JL models.
Old Nov 11, 2004 | 01:06 PM
eHoward's Avatar
I went into the audio shop looking to get the FX6-Hs but got upsold on the NX67s . . . also a drop in.
If you think you might amp the speakers with something other then head-unit power, I'd go for the NXs or a higher model. If you're just using the head unit, the FXs will do just fine.
Old Nov 12, 2004 | 08:42 AM
kgoroway's Avatar
Kicker amp already installed and powering the all stock speakers, and two 10" kickers in sealed enclosure...
I'll look into the NX67s, thanks for the tip. Can you confirm that they actually drop in? The Boston web page calls them 6.5" whereas the FX are called 6".
Anyone else have ideas?
Thanks.
-Kevin
Old Nov 12, 2004 | 12:26 PM
eHoward's Avatar
Default Re: (kgoroway)
I installed them in the doors of my 90 CRX. They came with spacers and fit in.
If I had a picture of them installed, I'd post it, but I don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kgoroway &raquo;</TD></TR><TR><TD CLASS="quote">Kicker amp already installed and powering the all stock speakers, and two 10" kickers in sealed enclosure...
Thanks.
-Kevin</TD></TR></TABLE>
Old Nov 12, 2004 | 12:50 PM
sopiwnykg's Avatar
Default Re: (eHoward)
He's trying to put them in an accord not a CRX. totally different cars.
Old Nov 12, 2004 | 04:06 PM
kgoroway's Avatar
Thanks sopiwnykg. You are correct... 98 accord.
I guess I'm back to the FX, which is sad since the NXs look to be a step up.
Other ideas?
Thanks!
sjbmx
Jul 2, 2008 02:33 PM
nappyroots827
Dec 20, 2006 07:11 PM
Tizzlers Ep3
Audio / Security / Video
May 22, 2006 03:22 PM
Battousai TT52
Apr 11, 2002 07:18 PM
Heat Rave R
Jan 25, 2002 09:35 PM
