Smoking after oil changes?
Old Nov 10, 2004 | 10:37 AM
kur0ryu's Avatar
Default Smoking after oil changes?
Hey guys, wondering if you can give me some insight to this issue:
I have a High compression b16a in a 91 CRX (See my profile for list of mods) and whenever I do an oil change I have heavy blue smoke billowing out until I run the car for a real long time (a week or so), then it appears really only on startup for 30 seconds. It especially smokes when I do left hand turns, thus led me to believe that it was a valve seal issue. So, I replaced all the valve stems with brand new honda factory seals. Changed the oil, and lo and behold, it still happens. I don't think it's my rings either, cuz I just did a compression test and my test shows:
Cyl 1: 265
Cyl 2: 270
Cyl 3: 255
Cyl 4: 260
Any ideas what could be causing it then?
Thanks in advance
Old Nov 10, 2004 | 01:06 PM
kur0ryu's Avatar
Default Re: Smoking after oil changes? (kur0ryu)
bub-ump
Old Nov 10, 2004 | 02:00 PM
derekcarr's Avatar
I am assuming that the smoke is comming from the tailpipe. Well if it's oil you might have the ring gaps lined up rather than spaced out on the piston. And you are sure that everything seated properly??? Oh and it could be left over oil in the cat.
Just ideas off the top of my head.
Derek
Old Nov 10, 2004 | 08:14 PM
kur0ryu's Avatar
Default Re: Smoking after oil changes? (derekcarr)
When I installed the pistons I made sure that they were spaced out. I'm pretty damn sure I did a good job making sure they seated properly too. Any other ideas?
Old Nov 12, 2004 | 07:21 AM
derekcarr's Avatar
Did you prime the motor after you did the seals or did you just fire it right up?? Can you do a leakdown test on it??
Derek
Old Nov 18, 2004 | 06:32 PM
kur0ryu's Avatar
I didn't know there was priming necessary after a seal change. Would that ruin the seals as soon as I put them on? Because the symptoms are the same before and after the change.
Old Nov 22, 2004 | 04:30 AM
derekcarr's Avatar
I just prime out of habit and you can never be too safe. Now when you did the seals I suppose you had a machinest look at the head right? It could also be the valve seats. If I get any other ideas I will post them up for you.
Derek
Old Nov 29, 2004 | 03:18 PM
kur0ryu's Avatar
when I did the seals, I did them with the head on, just pressurized the cylinder. As far as valve seats how would that affect it?
Snoxxy
11
Sep 14, 2008 01:19 AM
RvisionGSR
Mar 19, 2004 09:44 PM
Accel Junky
Apr 28, 2003 02:18 PM
AMChev
Sep 15, 2002 10:26 AM
