Got A Q, bout leanin toward a gsr swap, tried to search
Old Nov 10, 2004 | 07:49 AM
dzminiz's Avatar
Default Got A Q, bout leanin toward a gsr swap, tried to search
I'm lookin to do a gsr swap into my 93 SI, I'm looking at totaljdm.com
INCLUDED: tranny, ecu, Distributor,ntake Manifold,Exhaust Manifold,Alternator,AC Pump,Power Steering Pump,Vtec Solenoid,Half Shaft (Intermediate Shaft),
Available Options (if in-stock):
Axles: $75.00USD
Shift Linkage: $70.00USD
LSD: $400.00USD
What else Do I NEED TO GET??? I know theres a lot of you out there w/ this swap, I dont wanna get done then find out i needed something, i'll have to wait to get.
I'll order a mount kit from HASport, also.
Also any tips? maybe some wiring diagrams?
THANK U
Old Nov 10, 2004 | 07:54 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: Got A Q, bout leanin toward a gsr swap, tried to search (dzminiz)
IF your putting in a newer B series, you can use the mounts it comes with. You will need:
Engine, Hydro Trans, shift linkage, axles and ECU
You will probly need new radiator hoses, you will have to bypass your evap system unless you got a USDM ECU.
You will have to modify your wire harness to fit the new block, and I believe thats about it off the top of my head. Its not that hard, and the swap is pretty straight forward. I had my motor out, torn apart, reassembled with a new short block and back in the car and running in two days total.
Have fun!
Old Nov 10, 2004 | 08:19 AM
Slopoke's Avatar
Default Re: Got A Q, bout leanin toward a gsr swap, tried to search (JDM_Ej)
You will also need a gsr throttle cable.
Also figure in the cost for fluids. Engine oil, tranny oil, and coolant.
Old Nov 10, 2004 | 10:30 AM
dzminiz's Avatar
Default Re: Got A Q, bout leanin toward a gsr swap, tried to search (Slopoke)
Where Can/Should I order the throttle cable, radiator hoses and the mounts? Part Numbers? Also Any1 have a link to start up your newly swapped motor? I saw a page on it, but can't find it now. How do I go about bypassing the evap system?
I wanna keep my a/c do i use the pump included or my old one??
I just wanna make sure I get everything I need.
THANKS
Old Nov 10, 2004 | 10:56 AM
kyosoeg6's Avatar
not to be a dick man. but i have never posted this but u should really search man.
the honda-tech search feature is your best friend.
do u want ur swap to be as easy as possible? or do u want to take short cuts and cutdown on costs.
Old Nov 10, 2004 | 11:05 AM
spooncivic1's Avatar
i though you didnt need the throttle cable for a GSR swap? my friend just did one and used his stock one?
BTW im getting ready to do this swap and need to know if you can use the stock throttle cable?
Old Nov 10, 2004 | 11:21 AM
white ex's Avatar
Default Re: (spooncivic1)
Yes, you can use the stock throttle cable. Thats how i did mine.
Old Nov 10, 2004 | 01:14 PM
good one less part i have to buy
90civSi
Jul 14, 2005 10:35 AM
cbabyby
Mar 18, 2005 06:35 AM
Spoonedcivic
May 19, 2004 06:19 PM
p3s7
Oct 15, 2003 10:45 AM
budlight
Sep 29, 2002 10:28 PM
