all motor b16 v.s. all motor ls/vtec (race motor)
i was wondering what you guys would do. i have all the parts to do either one.
here is a run down of the parts i have
b16 and b18b block
endyen 13.5-1 81.5mm pistons eagle rods(rods are ls spec but i can order more)
p-n-p b16 head all stock (will buy cams when bottom end is decided)
99 si tranny
the motor will be race only but i do want it to last for a little while i know the ls/vtec has its probs,ive already blown one. i just dont want to sacrifice to much power by going with the b16.
is there any thing i can do by switching the cranks?
thanks for any info
b16 and b18b block
99 si tranny
thanks for any info
well, if you switch the ls crank into the b16 you gonna need custom raised height pin pistons. you wont be able to use your current pistons unless you use shorter rods wich you dont want to do.
your pistons are rated at 13.5 in what engine? whats the cc's on them?
thats kinda what i was thinking about i just want to do the right thing since i have all this stuff.this is what the pistons look like in the b18.i installed them before i ran across this b16
HondaTeKnology
54
Jan 4, 2008 08:16 PM
Nice green block
If you have any questions, if your serious going to go down the lsvtec road pm me!
