surging hatch
Old Nov 10, 2004 | 05:40 AM
VvPeachyvV's Avatar
Default surging hatch
my car is surging whenever its idle, and i'm not sure exactly what is the problem, i thought it might be the main relay bc i know i need to have it replaced.
Old Nov 10, 2004 | 05:43 AM
VvPeachyvV's Avatar
Default Re: surging hatch (VvPeachyvV)
vaccum leak?
Old Nov 10, 2004 | 05:48 AM
2lua's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VvPeachyvV &raquo;</TD></TR><TR><TD CLASS="quote">vaccum leak?</TD></TR></TABLE>
or your IACV.
Old Nov 10, 2004 | 07:17 AM
VvPeachyvV's Avatar
Default Re: surging hatch (2lua)
don't have an iavc, no vtec
Old Nov 10, 2004 | 07:19 AM
Ricey McRicerton's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VvPeachyvV &raquo;</TD></TR><TR><TD CLASS="quote">don't have an iavc, no vtec </TD></TR></TABLE>
No vtec != no iacv
Old Nov 10, 2004 | 07:25 AM
VvPeachyvV's Avatar
Default Re: surging hatch (Ricey McRicerton)
any ideas then bro?
Old Nov 10, 2004 | 07:53 AM
JeffS's Avatar
It could be any number of things. There are literally hundreds of posts just like this. Most of them get no replies because the author didn't provide any information. If you don't know enough to at least start troubleshooting it yourself, you'd be better off taking it to a professional.
The list of things that could cause a bad idle is too long to try to type out.
- FICV
- IACV
- any number of sensors, plugs, plug wires, ECU problem, O2 sensor etc
Old Nov 10, 2004 | 07:55 AM
Default Re: surging hatch (JeffS)
Does the idle surge when it's cold or when the car is warmed up or both? How badly does it surge? Have you done anything recently to the car?
Old Nov 10, 2004 | 08:53 AM
turboimports's Avatar
Yeah you should double check all your vacuum lines...check the IACV and the FITV.
-Lor
Old Nov 10, 2004 | 09:06 AM
VvPeachyvV's Avatar
it does it when warm or cold, i haven't done anything to the car besides my clutch kit and d16y8 tranny install.
Old Nov 10, 2004 | 10:29 AM
VvPeachyvV's Avatar
should i check the fast idle valve as well as the vaccum lines? bc it idles fast then slow, then fast again
Old Nov 10, 2004 | 12:04 PM
Go through them all....You never know what might be the problem unless you get into it.
Old Nov 10, 2004 | 12:06 PM
POE's Avatar
POE
clean your IACV screen with carb cleaner
GSX 4G63T
Feb 4, 2008 08:05 PM
dohcgarage@714
Honda S2000
26
Nov 8, 2007 11:29 AM
02spoon
Jun 25, 2005 08:16 PM
Aespooncivic
Apr 3, 2005 09:16 PM
tegnchewy
Oct 4, 2003 04:39 AM
