what is this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">Your pee pee? I know when I go fast mine pops up and squirts</TD></TR></TABLE>
bwahahahahaha
bwahahahahaha
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92civicsi05 »</TD></TR><TR><TD CLASS="quote">i need to know what this is
when i travel at fast speeds it pops up and squirts oil
You suck at the internet! Pic no worky!
</TD></TR></TABLE>You suck at the internet! Pic no worky!
Turbo does that to a man
Thats a valve cover hold down thing. You should have a screw on there.
In all seriousness, the screw snapped off in the rocker arm. Take off the valve cover and see if you can EZ-out the screw. I had the same problem, and couldn't EZ-out it so I had to get a new rocker arm assembly.
Valve cover bolt broken inside rocker arm assembly (under the 5):
thats the farmost bolt on the valve cover. it holds the valvecover to the head. could be a bad bolt. take it out, and replace. take off the valve cover and make sure it doesnt have a crack or leak. then make sure the bolt threads right and its ok and so is its hole.
do you often "travel at high speeds" inside your engine bay??....cause how else would you know when it happens??............thats sounds kinda dangerous, you must know first aid!!!!
</TD></TR></TABLE>do you often "travel at high speeds" inside your engine bay??....cause how else would you know when it happens??............thats sounds kinda dangerous, you must know first aid!!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath »</TD></TR><TR><TD CLASS="quote">looks like a vavle cover bolt from here</TD></TR></TABLE>yee!
looks like you might need a new grommet for it...and how woudl you know if it squirts out at high speeds?...do you phisically get out of your car at 140 mph(high speed) and check for leaks?...me no thinks so.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BauleyCivic »</TD></TR><TR><TD CLASS="quote">In all seriousness, the screw snapped off in the rocker arm. Take off the valve cover and see if you can EZ-out the screw. I had the same problem, and couldn't EZ-out it so I had to get a new rocker arm assembly.</TD></TR></TABLE>
And when you replace it, make sure not to overtighten or it will snap again! It only requires 7 lb-ft of torque.
iluvsleepers
Mar 14, 2004 02:05 PM
