400 whp build
hey guys... i have a bare b18a1 block with nothing in it at all ready to be built, and non vetc head. I just bought a turbo kit and i have about 8500 dollars to spend on motor build minus what it's gonna cost me for an LS trans with LSD quaff. my question is what will i need to get my engine built to handle boost high enough to create 400-480 whp... I don't wanna just buy a GSR motor. so do i need to just bore it out to 84mm with sleeves with LS Vtec conversion kit or can i stay non-vtec and hit my power goal.... i wanna know what types of pistons,rods, cams, everything.... i want alot of diff GOOD!!! opionions sooo if u don't have something good to input then plz don't post.. thx for the help
if you want 400 hp your gonna have to replace pretty much every internal thing in ur engine. buy a new head with cams, springs and retainers, ported and polished, everything already in it and save the hassle. build up the bottom end. but the thing thats most important is the way u tune it. get a hell of a fuel management system and get that bad boy tuned. i hope ur gonna do most of the work urself cause if you have a shop do all of it ur gonna go way over ur price range. good luck and let us know whats goin on. what kind of turbo kit did u buy?
rev hard stage2 upgraded drag turbo... im think ferrea ovesized valves crower cams and port and polish.. then je9:1 pistons eagle rods hondata.. oh yea im doin the work my self do i need like a 255 warlbro fuel pump
Im in the progress of building my project now....soo close to done...
This is all i have for now.
Stage 2 p&p Ls head w/ Crower 402turbo cams w/ skunk2 cam gears and Crower valvetrain
Skunk2 manifold w/ dh-racing 74mm port match TB
STR fuel rail and big hp fpr w/ 550's injectors and Walboro 255lhp
APR Head bolts
Golden Eagle 81mm sleeve/bore/hone/O-ring....
Wiseco 8.7 pistons w/ Eagle rods and ARP rod bolts
All brand new bearings
Blueprint to crankshaft micro...etc..
ITR Oil/Water pump
JDM GSR Tranny with Ls fifth gear
ACT HDPP 6puck and 7.5lb flywheel
Garrett T4OE w/ stage 3 turbine 63a/r
SP Long manifold
SP 3" dp w/ full 3" exhast
FMIC w/ all piping
HKS BOV
That's all, nothing special. Hopefully ill get into the 400hp range.
Modified by sPaRk'iT at 11:41 PM 11/10/2004
This is all i have for now.Stage 2 p&p Ls head w/ Crower 402turbo cams w/ skunk2 cam gears and Crower valvetrain
APR Head bolts
ITR Oil/Water pump
SP Long manifold
FMIC w/ all piping
HKS BOV
this should help, 515HP Integra
http://cs.widener.edu/~epanek/MikesGSRDyno.mpg
Car: 2001 Integra
Engine: GSR head (bone stock), 2.0 liter gsr block, GE sleeves, Wiseco 9:1 pistons, eagle rods (5/16 rod bolts).
Mods: Full race turbo kit, GT3040 52 trim .63a/r, 3" thermal exhaust, 1000cc injectors, stock fuel lines, stock fuel rail, aem fuel pressure regulator, Hondata intake manifold gasket, Hondata s100 with boost, AVCR boost controller, MSD blaster SS coil, NGK heat range 7 (pump gas) and heat range 9 (race gas) (stock ignition otherwise).
Car: 2001 Integra
if you have never done anything like this before then I would talk to someone and have them build and make the motor for you. You have to have a fully built motor or close to it prob running around 20-30ps or more. On and your gonna to get a standalone system like hondata or if you have the money a motec system. Also your gonna need new axles because you will be breaking your stock ones all the time. Go to Fullraces website its like fullrace.com. Get the motor built at a reputable shop like Larrys Endyn, Jeff at IB, or Jim Justice of Justice Racing. To have a motor make that kind of power expect to put 10 grand easy into it. I hope this is a drag car with slicks, cause your gonna go through street tires by the end of the day.
ive done builds like this before but never in the HP range im looking for mostly ive been in the 350's never 450+.... im not worried about the build itself i just don't wanna waste any of my money on things that are not needed.. so that when i comes time for the dyno if there is anything i lack ill still have the money for it...
im picking up the crower turbo cams boring out the block to 84mm righrt now... having it sleved.. i have je 9:1 psitons and eagle rods on the way... got the hondata intake manifold gasket and im on the way of getting the hondata installed soon.. just need to know what to do to the block other than just sleve it to be able to handle 22-28 lbs of boost
Just curious, what is the advantage in goin with 9:1 pistons when stock LS compression is like 9.2:1? Is it worth it for that small of a drop in compression?
95teilhatch
Feb 9, 2007 05:12 AM
