car was sitting, and now clutch fells full of playdo!
Old Nov 9, 2004 | 06:25 PM
90hatchie's Avatar
Default car was sitting, and now clutch fells full of playdo!
i dont know what to do about this. how do i fix it? do i need a new tranny or what?
Old Nov 9, 2004 | 06:39 PM
drdisco69's Avatar
Default Re: car was sitting, and now clutch fells full of playdo! (90hatchie)
If playdoh fell in your clutch, you should get it out.
If your clutch feels soft, try bleeding it.
I HIGHLY doubt you need a new transmission.
Old Nov 9, 2004 | 06:48 PM
90hatchie's Avatar
Default Re: car was sitting, and now clutch fells full of playdo! (drdisco69)
it doesn't feel soft it feels extremly hard to get it into gear, and like slides in.
Old Nov 9, 2004 | 08:50 PM
Quik89Si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">If playdoh fell in your clutch, you should get it out.
I HIGHLY doubt you need a new transmission.</TD></TR></TABLE>
How do you bleed a cable clutch?
Alex
Old Nov 10, 2004 | 02:26 AM
drussell4801's Avatar
Default Re: car was sitting, and now clutch fells full of playdo! (Quik89Si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Quik89Si &raquo;</TD></TR><TR><TD CLASS="quote">
Alex</TD></TR></TABLE>
hehe.. i wasn't going to say anything..
Mr T up there forgot what forum he's in.
Old Nov 10, 2004 | 05:22 AM
FULL-RACE EP3's Avatar
Default Re: car was sitting, and now clutch fells full of playdo! (drussell4801)
try drainging your trans fluid, and toppin it off with something new. Ya might even wanna try some of GM's synchromesh, it seems to work well with alot people who've tried it.
I dont know what else it could be really?
Old Nov 10, 2004 | 06:20 AM
Mighty's Avatar
Guys try to think about this logically.
The car has sat for a long time. It worked before it sat I assume.
I would check for rust and corrosion on the clutch cable and lever.
Also check for mice making a nest or something in the engine compartment.
You need to do a thorough inspection of the routing of the cable.
If that all looks good then youll probably have to pull the clutch and see what it looks like in there.
Also you might look at the clutch pedal there might be something hanging it up.
Old Nov 10, 2004 | 11:54 AM
90hatchie's Avatar
Default Re: (Mighty)
alright thinks man. ill give it a try when i can get to my car. too bad it wont be untill saturday.
Old Nov 10, 2004 | 12:04 PM
Brownjd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mighty &raquo;</TD></TR><TR><TD CLASS="quote">
I would check for rust and corrosion on the clutch cable and lever. </TD></TR></TABLE>
i had a '86 that did that same thing once, definately check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mighty &raquo;</TD></TR><TR><TD CLASS="quote">Also check for mice making a nest or something in the engine compartment.</TD></TR></TABLE>
there was a bird nest on top of the battery tray in a '85 i had sittin around for a long time
STEVE-O7
Oct 10, 2007 05:18 PM
ic89
Oct 17, 2006 11:59 AM
Lauj87
Sep 19, 2005 12:01 PM
one slow coupe
19
Jan 10, 2005 08:46 PM
AspectIndustries
Jan 5, 2004 07:49 AM
