P30 ECU in 93 si with B16a2? Will the pins and wires match?
you are looking at a plug and play swap, just use a 96-00 gsr harness and it will be the most plug and play swap you have ever done
Is the 93 si harness good? The 96+ is a obd2 right?
I want to make sure I don't burn out the ECU when I plug it in.
if u have a complete b16a2 swap with obd2 dizzy. just get a 99-01 gsr harness. that will plug right up to ur dizzy, you can keep ur current injectors and the ecu will also plug right up to the ecu harness in ur car.
you still need to wire up the knock sensor as the 93 si doesnt have one from the factory. the p30 will plug in fine to your ecu harness
BLKCivicPorscheStyle*
Aug 22, 2005 12:46 PM
