ECU?
Old Dec 24, 2001 | 06:52 PM
Accord15's Avatar
Default ECU?
I am trying to find out just for my general knowledge what ecu codes are. People are always posting stuff about p28 ecu or p something i am just wondering what they are from. Are they just aftermarket ECUs? Thanks for the help
Old Dec 24, 2001 | 10:08 PM
Kataku2K3's Avatar
Default Re: ECU? (Accord15)
ECU codes help diagnose ur car through the engine check light, either on ur ECU for OBD1 cars and in the gauge cluster for OBD1 and 2 cars. To view codes stored in the PCM on an OBD1 or 2 car install a jumper wire into the service connector located under the dash, kinda above the ecu. The check engine light will blink; a long blink representing the first digit and short blinks representing the second digit. (say, 2 long blinks then one short for the code 21 which is a vtec solenoid problem). I find all my codes from http://www.hybrid.honda-perf.org The P28, PR3, P30, P72, etc. those are just what kind of ECU you are talking about. (the P28 is an 92-95 SOHC VTEC computer, the PR3 is an OBD0 comp either from a JDM civic or integra, P30 del sol, P72 is an OBD1/2 GSR, and so on. Hope this helps!
[Modified by JDMspecEG6, 10:32 PM 12/25/2001]
Old Dec 25, 2001 | 08:35 PM
Accord15's Avatar
Default Re: ECU? (JDMspecEG6)
thanks man
HAMOTORSPORTS
Performance
172
Sep 29, 2017 11:00 AM
Ef4doorwagon
Mar 11, 2015 05:59 PM
Tong.Y
Nov 12, 2010 05:09 PM
hondateg10
Mar 25, 2007 03:50 PM
CRXb18Turbo
Oct 20, 2005 05:48 PM
