short throw shifter
Old Nov 9, 2004 | 04:16 PM
Legato's Avatar
Default short throw shifter
hi i recently put a short throw shifter in my car and i noticed there is alot of play in gear but it was also like that with my stock shifter someone told me that it goes **** boot snap ring bearings or bushings but there were none on my car when i took the stock one off its a 97 civic dx can any one help me? i was looking for a diagram online i had no luck i want to get a manual but thats 20 bucks i dont have at the time any help would be appreciated thank you
Old Nov 9, 2004 | 05:32 PM
97dxnut's Avatar
Default Re: short throw shifter (Legato)
if you get some shifter bushings from either energy suspension or protane that should clear up some of the slop in the shifter. there are 2 in a set. 1 up near the transmission and 1 on the back of the thing that holds the shifter up to the body. If you look under your car you'll see what i mean
Old Nov 9, 2004 | 05:41 PM
TurboTagTeam's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97dxnut &raquo;</TD></TR><TR><TD CLASS="quote">if you get some shifter bushings from either energy suspension or protane that should clear up some of the slop in the shifter. there are 2 in a set. 1 up near the transmission and 1 on the back of the thing that holds the shifter up to the body. If you look under your car you'll see what i mean</TD></TR></TABLE>
Definatly what it is
Old Nov 10, 2004 | 08:51 AM
darkstarcivic's Avatar
Default Re: short throw shifter (TurboTagTeam)
i also recently installed a short shifter and it seems to rub on i guess it would be a heat sheild cuz its fine shifting from 1-2-3 then its a little harder to get into 4th and 5th and reverse is also alittle rough.so i put the stock one back in i didnt know if this was normal or if it would screw up my transmission.any sugg.it is a ebay buy but it looks identical to the neuspeed shifter.
Old Nov 10, 2004 | 08:58 AM
klungemonger's Avatar
Usually you only get rubbing with the cheap shifters like Ebay ones (yes, I DID have one). Over time they rot out and get sloppy too. Solution: stay with stock (shorties don't really give you any true added performance anyhow) or get one that uses stock pivot type like B&M. You can only shift so quickly an not be cranking on your synchros.
darnizzle8805
Jun 20, 2014 06:04 PM
x_tuh_sy
Dec 8, 2007 12:03 PM
96electronH
31
Nov 19, 2007 07:31 PM
CTR-GSR
Feb 24, 2006 09:47 PM
zseeanz
Jan 3, 2004 09:04 PM
