Rookie Mistake (need expert advice!! Please
I f*cked up big time after doing a perfect valve adjustment. I tightend two of the valve cover bolts to tight and they snapper off. I actually didn't really tighten it that much, it snapped off pretty easy. If anyone can direct me to a site that sells replacement studs or has a partnumber or anyway of fixing this, that would be great. Thanx in advance
No biggie, I did the same thing last week. take a run to your local acura dealership and go to the parts dept. tell the great people behind the counter what you did and they'll let you take a peak on their computer to identify exactly which studs are broken. they've probably got them in stock. their are two different lenths if i recall. it's easy to put the new ones on though. just use an open ended or deep socket 10mm... or was it 12mm? either way, you ge the idea. It's a pie job. And the more I think about it, I think it was 10mm. Just take your time and don't torque it in their so hard.
You guys Rule! Thanx for the help. I'll be calling the dealership on wednesday, and hopefully they have it in stock. If not, I'll just have to buy some off you Halo
86 inch pounds. I have one that is snapped. I was going to replace it when I did my valve adjustment, but forgot to buy the nut that goes on top. I have the chrome one only
Hopefully, I will get it right next time.
http://www.c-speedracing.com/howto/v...lveadjust.html
[Modified by Spade, 1:53 PM 12/26/2001]
how do you adjust the valves?
yea how do u adjust the valves???
damn man this site rules!
this is great thanks for the help!
From: Formerly of SF moved to DFW and now back in SF, CA, USA
The top nuts should be tightened down to 7.2 ft/lbs. (helms manual)
You can go to any dealer and they should have them or order them for you. Otherwise go to http://www.ahmotor.com for honda parts.
I was replying to 1fastgsr who was commenting about the stud. That is 19ft lbs. The 10 mm acorn nut can be tightened by hand. Just make it snug. You don't need to torque that.
oneEg1Tc
12
Nov 21, 2009 07:57 PM
mike03,95civic
Dec 12, 2008 01:39 PM
Eibach95Civic
Apr 5, 2007 12:33 PM
