Stock LS Turbo Question
Hey, im investing in a DIY turbo setup for my stock 94 LS and just wanted to know:
1) If i use a decent Garrett t3/t4 and nice IC, what power output should i expect, with decent tuning?
2) What would be the max boost you could safely run on a stock LS? I have heard 8 from some and others up to 11. I want the engine to last a decent life. I dont have the money to replace an block in 5k miles.
3) Is uberdata reliable enough to chip a stock LS ecu for boost?
i just tuned a bonestock ls with a t3/t4e on it and it made 250whp/222wtq at 10-11psi with uberdata...runs like a champ and i expect it to for quite a while a/f was in the high 11's and total timing was at 19 degrees
ive heard of people pushing more but i wouldnt do it on a daily driver.
Read this thread: https://honda-tech.com/zerothread?id=791535
Rob is a buddy of mine and that car has been running that exact same setup for a long time now.
I run a stock LS, uberdata tuned on 9 psi (soon to be turned up) and I drive it everday. I expect it to last because it is tuned correct. Uberdata is an excellent program IMO
Phil
.Phil
BoostedD15B7
Apr 16, 2003 09:13 AM
