Crank Pulley noise
Old Nov 9, 2004 | 09:38 AM
this name is gone's Avatar
Default Crank Pulley noise
ok for the last 2 days there has been a sqeeling from my crank pully. only at idle tho. now today the is a vibration from 3k-4k rpms. what could the problem be. and how can i fix it? thanx
-Kyle
Old Nov 9, 2004 | 09:50 AM
Brownjd's Avatar
Default Re: Crank Pulley noise (BseriesCrx)
check all your belts including timing belt. make sure the crank bolt is tight. i actually had the crank pulley come off on me one time and the timing belt chewed thru the cover and was very close to completely coming off before i stopped
Old Nov 9, 2004 | 09:54 AM
Default Re: Crank Pulley noise (Brownjd)
i was thinking a belt the alternator belt is fine and the pulley itself doesnt move around so that looks good but i will check again. how do i take the timing belt cover off? should i just take the top part off and see if its tight or what? also i have a valve cover that has the timing belt cover part cut off. should i put taht on start it up and see what happens?
-Kyle
Old Nov 9, 2004 | 10:00 AM
Brownjd's Avatar
you can just take the plastic timing cover off and check the belt. your tensioner may be bad
Freemananana
Oct 24, 2015 10:22 AM
Sherm
Sep 18, 2009 06:09 AM
1994CivicGS-R
Mar 14, 2006 03:05 PM
IntegracinGSR
Aug 21, 2004 08:43 PM
sbigblack02
Apr 3, 2004 07:21 AM
