gsr questions (blinking check engine with mileage)
Old Nov 9, 2004 | 05:52 AM
Chris_Bye's Avatar
Default gsr questions (blinking check engine with mileage)
okay, my gsr has 100,500 miles on the body but not sure how many on the motor (motor was stolen). So the other day i was at a meet and the check engine light started to blink after i turned the car on. It went off after a couple seconds, and blackonblackteg showed me how to just turn it off completely.
my question is at what mileage does this light start to blink? Is there a certain mileage? I have an idea of how many miles are on the motor, about 80k.
Old Nov 9, 2004 | 05:59 AM
White GSR '01's Avatar
Default Re: gsr questions (Chris_Bye)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote">okay, my gsr has 100,500 miles on the body but not sure how many on the motor (motor was stolen). So the other day i was at a meet and the check engine light started to blink after i turned the car on. It went off after a couple seconds, and blackonblackteg showed me how to just turn it off completely.
It doesn't blink after a certain amount of total mileage. That is if you are talking about the sevice engine soon light. It comes on when you need an oil change. After about 5k it will start coming on when you start the car. If you don't reset it it will eventually come on and stay on. The little reset button under the steering column should fix that.
Old Nov 9, 2004 | 06:00 AM
JimBlake's Avatar
I'm guessing it was the 'maint. reqd.' light that was flashing. On my '95 it comes on every 7500 miles because that's the service interval. It starts to blink a few hundred miles early, then at 7500 it stays on. Reset it with the button under the dash.
The check-engine light is triggered by problems the ECU finds. It's not based on mileage at all. You can reset that one by disconnecting the battery for a minute, but if you haven't fixed the problem it'll come right back on.
Old Nov 9, 2004 | 06:01 AM
Chris_Bye's Avatar
Default Re: gsr questions (White GSR '01)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote"> It went off after a couple seconds, and blackonblackteg showed me how to just turn it off completely.
okay, so every 5k miles? yeah and i already knew how to shut the light off^^
Old Nov 9, 2004 | 06:03 AM
Chris_Bye's Avatar
is there any way that i can find out how many miles my motor has on it?
Old Nov 9, 2004 | 06:08 AM
okay, so every 5k miles? yeah and i already knew how to shut the light off^^ </TD></TR></TABLE>
No, every 7500 miles, I was wrong.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote">I'm guessing it was the 'maint. reqd.' light that was flashing. On my '95 it comes on every 7500 miles because that's the service interval. It starts to blink a few hundred miles early, then at 7500 it stays on. Reset it with the button under the dash.
Old Nov 9, 2004 | 07:09 AM
DOHC-ter AMIEL's Avatar
if it is the check engine light and not the maint required light then i suggest you pull the code. you can do it yourself or pep boys can do it for you for 19.88 with tax and all. i went to pep boys and they found that my check engine light was triggered due to low voltagge to the throttle positioning sensor. the guy was cool and fixed it for free
Old Nov 9, 2004 | 08:31 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote">is there any way that i can find out how many miles my motor has on it?</TD></TR></TABLE>Only if you have a receipt or something showing what mileage the car had when it was done.
The light comes on for mileage from the last time it was reset. So if you drive around for 6 months with it on, it counts miles from the point when it was reset. So if you want to use the light, you'll have to do that in order to synch it to your engine's schedule.
Old Nov 9, 2004 | 09:28 AM
zippyLS's Avatar
Default Re: gsr questions (JimBlake)
If your car is 1996 or newer, advanced or autozone will check it for free.
Old Nov 9, 2004 | 10:46 AM
Default Re: gsr questions (AMIEL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMIEL &raquo;</TD></TR><TR><TD CLASS="quote">pep boys can do it for you for 19.88 with tax and all. </TD></TR></TABLE>
Buy a Haynes manual for $15, then read the code the ECU gives you and you will know right there.
Old Nov 9, 2004 | 11:02 AM
Copy Cat's Avatar
My check engine light started blinking but right when it started blinking my motor started to have bad idle, shook like and smoked like a mother ******. Also my oil smells like gas. I am stuck here at college ( 2.5 hrs away from home) and i risked taking it home, thank God i made it. I havent had time to pull the head to see whats up but im sure its the rings. my compression was mad low on cyl 2 and i burned 4 qts of oil in 115 miles.
Im pretty sure your all good though. Just get the code and fix her up.
Old Nov 9, 2004 | 03:58 PM
Chris_Bye's Avatar
Default Re: gsr questions (CivicFerioViRs)
is there an actual light that says maintenence required? or is it just the check engine light blinking?
Old Nov 9, 2004 | 04:07 PM
zippyLS's Avatar
yes, there is a light that says "maint reqd" and a light that says "check"
Old Nov 10, 2004 | 03:47 AM
JimBlake's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote">is there an actual light that says maintenence required? or is it just the check engine light blinking?</TD></TR></TABLE>Yeah, there's 2 separate lights. Which one are you talking about?
Old Nov 10, 2004 | 04:23 AM
Chris_Bye's Avatar
i turned it off from that switch on the bottom, i think it was the maintenence required light, can't remember
Old Nov 10, 2004 | 04:31 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris_Bye &raquo;</TD></TR><TR><TD CLASS="quote">i turned it off from that switch on the bottom, i think it was the maintenance required light, can't remember </TD></TR></TABLE>
It WAS the "Maintenance Required" light. The check engine light can only be shut off by the ECU when the problem the car is having is fixed.
Old Nov 10, 2004 | 07:28 AM
furious94ls's Avatar
You need the vin number of the motor and run a carfax. That can give you an idea. Otherwise you should have recieved paperwork with your new motor which would disclose the mileage on it.
Old Nov 10, 2004 | 05:22 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by White GSR ’01 &raquo;</TD></TR><TR><TD CLASS="quote">
Buy a Haynes manual for $15, then read the code the ECU gives you and you will know right there. </TD></TR></TABLE>
thats true so very true. i have a haynes book. but when it comes to stuff like this i'd rather have a proffesional do it. its only a couple of more bucks and i get the feeling of security cause i know that someone who is certified is working on my car
Neo218
Apr 6, 2010 10:19 AM
TDCTyler
Feb 26, 2007 03:28 PM
tsdenny
12
Aug 7, 2005 10:25 AM
casmello
Apr 7, 2005 04:02 AM
goldievt
Aug 11, 2002 04:52 PM
