Y8 'Mini ME' on ad D16A6 - need some help.
Old Nov 8, 2004 | 10:39 PM
kess's Avatar
Default Y8 'Mini ME' on a D16A6 - need some help.
I have a Y8 head and intake manifold. Hopefully the injectors and fuel rail are on the way. I would also like to put in a new timing belt. I have heard that:
- I need a special head gasket.
- The Y8 MAP sensor is not compatable with the A6 one.
- I may have OBD-0 to OBD-1 compatability issues.
- I should use the injectors from the A6 head instead of the ones from the Y8 head, as they cannot 'talk' to each other.
- I should get an HX timing belt.
Looking for expertise on these issues and any other that may be of concern. I have an Apexi VAFC to control vtec timing.
Modified by kess at 9:10 PM 11/9/2004
Old Nov 8, 2004 | 10:42 PM
mike_belben@yahoo.com's Avatar
From: not riding any bandwagons in, massachusetts, usa
Default Re: Y8 'Mini ME' on a D16A6 - need some help. (kess)
take a look at the valve relief spacing of an a6 piston and a y8 piston. notice they are different widths?
Old Nov 8, 2004 | 10:59 PM
EJ2-Fluffy's Avatar
Default Re: Y8 'Mini ME' on a D16A6 - need some help. (mike_belben@yahoo.com)
So your doing a mini-me swap? So am I and I've been asking myself the same questions and here's what I've came up with.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">I need a special head gasket. </TD></TR></TABLE>
Use the d16z6 headgasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">The Y8 MAP sensor is not compatable with the A6 one.</TD></TR></TABLE>
Not sure about this one.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">I may have OBD-0 to OBD-1 compatability issues.</TD></TR></TABLE>
I thought the Y8 was the 96-00+ civic engine models which consisted of the OBD-2 system. I think you will have to get some OBD-O to OBD-2 conversion harnesses. Or you could use the Z6 ecu and injectors and use the OBD-0 to OBD-1 conversion harness. If you have a car w/ Duel point fuel injection, you will need to switch to Multi port fuel injection wiring. (http://www.pgmfi.org)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">I should use the injectors from the A6 head instead of the ones from the Y8 head, as they cannot 'talk' to each other.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">I should get an HX timing belt.</TD></TR></TABLE>
It's a Y8 head. I've always thought you are suppose to use the water pump, timing belt of fthe Y8 head unless I'm wrong. Can someone correct me on this?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kess &raquo;</TD></TR><TR><TD CLASS="quote">Looking for expertise on these issues and any other that may be of concern. I have an Apexi VAFC to control vtek timing.</TD></TR></TABLE>
If you have the VAFC to control the VTEC, I think you can still use the SI ECU unless I am wrong. I haven't really researched OBD-2 systems but I know for the mini me w/ CRX SI (pm6) ecu you can run the VTEC solenoid to an RPM switch to activate it.
Hopefully I helped in some way. I suggest getting some Helm's manuals which show the wiring diagrams for your Y8 engine head and the car your working on.
Good luck.
- Jon
Old Nov 8, 2004 | 11:53 PM
kyosoeg6's Avatar
Default Re: Y8 'Mini ME' on a D16A6 - need some help. (CRX-Fluffy)
i used a z6 belt on a a6/y8 minime no probs. also on the a6 block when u pull the head, u will need to drill out or tap out a plug for oil. i cant really say how it looks but ill get a pic up asap. on the injectors u need to use the a6 ones. and as far as the dizzy goes im not too sure. im not very familiar with ob0 cars yet. but i got a crx and im going to start learning
Old Nov 9, 2004 | 05:06 AM
crx_88_si's Avatar
you don't drill/tap it out.. it pops out w/ a screw driver...
http://crx.honda-perf.org/arti....html
also.. you'll need head bolts for a y8, as one is different near the dist.. (or you'll need that 1 bolt, if u can buy "1").
use the y8 head gasket, its metal, not paper whatever like a6/z6 ones. (stronger)
Old Nov 9, 2004 | 08:09 PM
kess's Avatar
Thanks for the help. As I see it I will need:
Y8 headgasket
Y8 head bolts (ARP?)
A new timing belt. Z6 or Y8?
A6 injectors and fuel rail (off my old A6 head)
Also there is a MAP sensor is attached to the Y8 head, but the MAP sensor on my '88 CRX si is mounted on the firewall. How is this resolved?
OK, now more dumb questions. What cars had the Z6 heads and what cars had the Y8 heads? '92-'95 Civics (for both?). And what spark plugs should I ask for (yes I know - Y8. But does anyone recommend specific brands/part numbers?).
Stay with me please - I'm getting close...
Old Nov 9, 2004 | 08:17 PM
Gumbey75's Avatar
z6's came off of del sol si's. and y8's come off 93 n up civic ex's
Old Nov 9, 2004 | 08:31 PM
mellon's Avatar
Default Re: Y8 'Mini ME' on a D16A6 - need some help. (Gumbey75)
Keep in mind the z6 headgasket will give a lower compression then if you used the y8. You might want to keep the compression down if you plan on going FI or if you don't want to deal with a high compression engine.
Old Nov 9, 2004 | 08:43 PM
kess's Avatar
Default Re: Y8 'Mini ME' on a D16A6 - need some help. (mellon)
I'm OK with high compression. I know I must run Premium, but WTH.
So will either a Z6 belt (from a '92 - '95 Civic ex/si) or a Y8 belt (from a '93+ Civic ex) work?
Old Nov 9, 2004 | 08:49 PM
deftones0817's Avatar
z6s are 92 - 95 civic 96 up are y8
yeah im doing one too didnt know about the head bolts good info
Old Nov 9, 2004 | 08:51 PM
4drEF's Avatar
Keyboard Humorist
My 5 hints.
1) You can use the Y8 injectors.
Only trick to it is do not use the injector resistor box.
If you use the A6 injectors you have to use the injector resistor box.
2) Z6 and Y8 headgaskets are now the same part number.
They used to be different and the Y8 gasket used to be thinner = slightly more compression.
3) You can run OBD-0 or OBD-1. The distributor selection depends on the ECU you plan to use.
If you want to use the A6 (PM6) ECU then you will need to use the A6 distributor. Also, you will need to buy something to activate VTEC and bump up fuel during VTEC. VAFC is a good solution.
Going OBD-1 (P28) will require that you do the necessary wiring conversion. You can use a 92~95 DX distributor (bolt pattern is correct) or use the Y8 distributor.
4) I believe the Z6 and Y8 timing belts have the same number of teeth. Same number of teeth = same length.
5) You will have both map sensors in the car so try either one. I think they both should work, but you can find out for yourself. For OBD-1 the Y8 one works for sure.
Old Nov 9, 2004 | 09:17 PM
kess's Avatar
Default Re: (4drEF)
OK. So are Y8 injectors larger (flow more) than A6 injectors?
BTW I have two CRX's. My other one is a '90 si with a Jackson Racing supercharger. That is serviced by a Zdyne gold ECU. Is it possible that I can tune this setup in my '88 'mini-me' si with my Gold ECU? I would just save the tunes on my laptop.
Its getting interesting...
Old Nov 10, 2004 | 02:51 PM
kess's Avatar
Default Re: (kess)
OK - Its a metal head gasket from a 96+ Civic and the same timing belt should also work. Ant more issues that I sjould be aware of?
MAN this thing scrolls fast!!!
EJ6_OB
12
Aug 10, 2012 10:27 AM
94dxt
Nov 3, 2009 02:02 PM
VtecKiDD
10
Sep 1, 2006 07:56 AM
DA91TEGGY
Apr 19, 2005 03:55 PM
boostedcivicsir
Mar 10, 2005 05:42 PM
