b seriers blocks
Old Dec 24, 2001 | 02:17 PM
chad's Avatar
Moderator
Default b seriers blocks
what are the differences?
b16a first gen
b16a sir II
b16a2 (99 up si's usually del slows too)
b18a
b18b
b18c
b18c5
b20z
b20b
are all the blocks the same? is the bore the same on all and just the stroke change?
are all bolt locations the same?
i know certian sensors won't be there like knock and crank fluctuating (99 ups)
thanks
chad
Old Dec 24, 2001 | 05:46 PM
Katman's Avatar
Default Re: b seriers blocks (chad)
b16a first gen
b16a sir II
b18a
b18b
b18c
b18c5
b20z
b20b
thanks
chad
ok, mechanically here's the differences..
JDM 89-91 B16A (cable type) = 10.2 cr. The PR3 piston is lower comp. than the newer JDM 92+ B16A.
JDM 92-01 B16A (hydro type) = 10.4cr. The P30 piston is higer comp. because of the higher dome'd piston than a PR3 piston.
US 93+ B16A all use a JDM PR3/10.2 c.r. piston, even the Si coupe.
Cam profiles on the 89-91 b16a are pretty weak. the 92+ B16A or 94+ GSR cams are better to use ...or..of course you can go R cams to make more power.
..i'm not gonna even mention jiggedy jack **** about the B18/LS engines. Not worth my time.
JDM B18C/SiR-G (180hp non-R engine) has changed pistons as well and is rated at is 10.6 cr.
US B18C1 (170hp) has flat pistons and is rated at 10.0 cr.
The head, and all other B18C/P72 mechanical parts are all basically the same.
Although the JDM B18C/SiR-G ECU sucks ***...you're bettter off using a US GSR ECU on this engine.
JDM ITR engine also has a better/higher compression piston vs. the US ITR engine.
11.0= JDM ITR piston
10.6=US ITR pistons
camshafts are identical- but in 00 the profile changed to that of CTR cam specs for both US and JDM version. JDM ITR ECU sucks too, US one is better.
B20....i'm outta breath right now....get back to you on that....
he JDM 89-91 B16A engine has a lower compression (10.2) than any 92+ JDM B16A (10.4) and that is because of the PR3 piston dome.
All JDM 92+ B16A's have the same P30/10.4 piston.
Old Dec 24, 2001 | 05:56 PM
chad's Avatar
Moderator
Default Re: b seriers blocks (Katman)
thanks Mr. Kat!
Old Dec 24, 2001 | 06:44 PM
HXMan's Avatar
b18c has a higher deck height then the b16's.
b18b, b20b/z don't have piston oil squirters, VTEC engines do(except for the D series.
Old Dec 24, 2001 | 06:45 PM
chad's Avatar
Moderator
Default Re: b seriers blocks (HXMan)
what about bolt holes on exterior of block? mount positions the same?
Old Dec 24, 2001 | 07:10 PM
non-VTEC's Avatar
how about the B20A found in the older preludes?
kinda of a POS engine but never the less it's a B-series
Old Dec 25, 2001 | 10:55 AM
samiam's Avatar
Default Re: b seriers blocks (non-VTEC)
yeah .. in it's own class...
Old Dec 25, 2001 | 09:44 PM
Katman's Avatar
yes, all bolt holes are the same as far as the block goes. That's why you can bolt in any year B series block into a 92+ civic with the use of integra mounts.
Old Dec 26, 2001 | 07:21 AM
Spade's Avatar
We are all forgetting one thing that I didn't see mentioned in this post.....the B20 blocks come with an 84mm bore. They are an LS engine with a larger bore......
Old Dec 26, 2001 | 09:13 AM
MGD's Avatar
MGD
hey katman,why are the jdm b18c ecu's garbage. What program would you use on this ecu ?
Old Dec 26, 2001 | 09:18 AM
rainforest's Avatar
Default Re: b seriers blocks (A42NV)
b16/17 are 263mm deck and all the above are 270mm deck the 18's and 20's .
Old Dec 26, 2001 | 01:07 PM
chad's Avatar
Moderator
Default Re: b seriers blocks (rainforest)
thanks everyone!
iamalex1212
Feb 23, 2009 06:49 PM
BlackHXCoupe
Jul 21, 2006 12:48 PM
b16a27
Nov 1, 2004 12:50 PM
eddie1681
Feb 7, 2002 06:08 AM
prospeed
Dec 27, 2001 11:43 AM
