Door speakers........
Old Nov 8, 2004 | 04:39 PM
RemerLex11's Avatar
Default Door speakers........
to replace them you need to take all the paneling off.......is it that difficult???? im worried about messing it up
Old Nov 8, 2004 | 04:47 PM
AndyD's Avatar
Default Re: Door speakers........ (mafoo_2005)
On my 4th gen, I had to take the door panel off. Not difficult to do. Just take your time with the and pop the panel off slowly and evenly.
Old Nov 8, 2004 | 04:51 PM
Daboi630's Avatar
Please be careful with the window switches
Old Nov 8, 2004 | 04:58 PM
black92lude's Avatar
Definetaly be careful with the window switches.......moreso when you are putting the panel back on then when taking it off......it is sometimes diffucult to make them fit right, but take your time and you will eventually get it.
Old Nov 12, 2004 | 10:58 AM
RemerLex11's Avatar
Default Re: Door speakers........ (black92lude)
where do u pull the door panel off on a 4th gen..........do u just pull it from the bottom??
Old Nov 12, 2004 | 11:05 AM
Slatelude's Avatar
1st, pop off the triangular piece where the mirror attaches (flat head screwdriver works good). Then remove 4 (?) screws (1-behind the door handle, 1-down in the recess in the arm rest, 1- top part of front of panel, and 1- lower part of back of panel. then there is a gap running between the panel and door along the bottom, go to one end of that and just give it a sharp/but brief tug, should start to pop loose. work your way around popping out all the fasteners, then lift up so it slides out of the window well. Just take your time, and remeber (its meant to come apart so if it really doesnt want to, theres probably a step you missed)
Kevin
Old Nov 12, 2004 | 11:23 AM
SKDRCR's Avatar
Default Re: Door speakers........ (Slatelude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slatelude &raquo;</TD></TR><TR><TD CLASS="quote">1st, pop off the triangular piece where the mirror attaches (flat head screwdriver works good). Then remove 4 (?) screws (1-behind the door handle, 1-down in the recess in the arm rest, 1- top part of front of panel, and 1- lower part of back of panel. then there is a gap running between the panel and door along the bottom, go to one end of that and just give it a sharp/but brief tug, should start to pop loose. work your way around popping out all the fasteners, then lift up so it slides out of the window well. Just take your time, and remeber (its meant to come apart so if it really doesnt want to, theres probably a step you missed)
Kevin</TD></TR></TABLE>
You don't have to pull the triangular piece to remove the door panel.
Like stated before, be careful with the window switches.
It can be tricky removing the panel around the handle
where the switch is.
Old Nov 12, 2004 | 08:30 PM
RemerLex11's Avatar
Default Re: Door speakers........ (SKDRCR)
to replace the door speakers can i just take the bottom part of the panel off or do all the panels on the door have to come off?
Old Nov 12, 2004 | 08:33 PM
Daboi630's Avatar
there is only one panel, you remove it to gain access to the speaker screws
bb6kid22
Sep 25, 2008 05:36 AM
ludedude00
May 5, 2005 06:09 AM
206civic
Jan 8, 2005 11:43 AM
1997exciv12w3
Sep 3, 2002 05:12 PM
96 Accord Ex V6
Oct 21, 2001 08:03 PM
