VTEC only works in 3rd gear
Old Nov 8, 2004 | 04:38 PM
matto2413's Avatar
Default VTEC only works in 3rd gear
its weird my VTEC only kicks in, in 3rd gear. I get a check engine light once in a while for VSS. But it doesnt matter if its on or off, VTEC will only kick in, in 3rd gear. any ideas why??
Old Nov 11, 2004 | 10:53 PM
Mikizzle's Avatar
im pretty sure its kicks in all your gears. probably 1st and 2nd gears go by to fast for you to notice the vtec.
Are you basing your vtec on when the noise changes? or when it actually feels different?
try and gun it in 2nd gear while going like 20mph or something and tell us what happens
Old Nov 12, 2004 | 08:24 AM
Gsr_Hybrid_theory's Avatar
Default Re: (grn4drgsr)
vtec works off of a # of things, oil press, etc, vss, as well as others....
if ur vss isnt correctly measuring, then the vtec will not work crrectly
Old Nov 12, 2004 | 08:27 AM
m R g S r's Avatar
Default Re: VTEC only works in 3rd gear (matto2413)
U sure it's vtec, not the secondaries?
EDoTdc2's Avatar
Default Re: (Gsr_Hybrid_theory)
i dont understand how it could only work in 3rd.. seems a lil odd
Old Nov 12, 2004 | 08:37 AM
vain's Avatar
vtec works based on a few factors.. none of which are what gear you're in.
Old Nov 12, 2004 | 09:24 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (vain)
<-- waits for somebody to ask "so does that mean mah V-TECH will work in reverse???"
Old Nov 12, 2004 | 09:39 AM
vain's Avatar
Default Re: (PatrickGSR94)
lol.. reverse is a special case
Old Nov 12, 2004 | 12:16 PM
TunerN00b's Avatar
Default Re: (vain)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">lol.. reverse is a special case </TD></TR></TABLE>
Is it really though? I've never tried, but assuming the ecu doesn't look at gear selection, if you have all the other requirements met (rpm, oil pressure, engine warm enough, throttle open enough) shouldn't vtec kick in? If I'm off on the requirements, feel free to correct me, I'm no expert.
So, who wants to try and get vtec to activate in reverse? You'd be moving at like what, 35mph?
Old Nov 12, 2004 | 12:24 PM
simon98h22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">&lt;-- waits for somebody to ask "so does that mean mah V-TECH will work in reverse???" </TD></TR></TABLE>
LOL
Old Nov 12, 2004 | 12:53 PM
vain's Avatar
actually. you can get into vtec in reverse. why you would want to do it is beyond me. given the gear ratio for reverse, i imagine you could hit about 30mph.
Old Nov 12, 2004 | 01:39 PM
matto2413's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grn4drgsr &raquo;</TD></TR><TR><TD CLASS="quote">im pretty sure its kicks in all your gears. probably 1st and 2nd gears go by to fast for you to notice the vtec.
try and gun it in 2nd gear while going like 20mph or something and tell us what happens</TD></TR></TABLE>
Im going by both how it sounds and by the way it feels. You can feel VTEC kick in, and in first and sometimes in second it does neither somedays. Other days it'll work fine. I also sometimes through a CEL for my VSS. But VTEC still kicks in with the a CEL.When i say that it doesnt kick in, in 1 and 2 im talkin about with no CEL though.
Old Nov 12, 2004 | 10:26 PM
yee SERIOUS's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gsr_Hybrid_theory &raquo;</TD></TR><TR><TD CLASS="quote">vtec works off of a # of things, oil press, etc, vss, as well as others....
if ur vss isnt correctly measuring, then the vtec will not work crrectly</TD></TR></TABLE>
i will have to go with this answer. post the code number and maybe i can check it out tomorrow at the dealership if i have time.
i'm still not too sure of what you're trying to say. i'm sure vtec will still work with a cel. as long as the things it works off of are met. when does your CEL come on? in 3rd only? not 1st or 2nd? and do u reset your ecu so that the CEL will go away? or does it go away after a few drive cycles?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vain &raquo;</TD></TR><TR><TD CLASS="quote">actually. you can get into vtec in reverse. why you would want to do it is beyond me. given the gear ratio for reverse, i imagine you could hit about 30mph. </TD></TR></TABLE>
i've never seen anyone go over 3grand in reverse. that would be interesting to see someone go 30mph in reverse.
Old Nov 13, 2004 | 01:50 AM
nub.96ek's Avatar
Had the same prob w/ my 92 GSR... turnes out to be the wirng to the ecu from the pressure switch. Don't know why only in 3rd but when I replaced the wiring all was well
taakuumii!!
29
Aug 17, 2018 10:14 PM
Lightsped
26
Jan 8, 2009 02:09 PM
bb_SI
11
Jun 26, 2008 06:13 PM
an2ny888
Mar 1, 2004 01:04 PM
ALL-MOTOR-BUBBLE
Mar 18, 2003 10:05 PM
