tranny is knotchy after the motor warms up
The tranny is a JDM ITR with 4.78 FD. CM flywheel and exedy organic clutch, skunk2 shifter.
The tranny shifts super smooth until the car is warmed up real good and then it has difficulty going into first and second. It becoms very apparent at the road course when I beat on my car for awhile and then come off the course and the tranny will barely get into first.
Anyone ever have similar experiences? Ideas?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by red civic standard »</TD></TR><TR><TD CLASS="quote">I am currently using GM syncromesh (not friction modified).
Would it make a difference if I bought the friction modified?</TD></TR></TABLE>
lol
from worse to more worse.
use something that will actually protect your gearbox better than oem.
lol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by w@@t w@@t »</TD></TR><TR><TD CLASS="quote">
lol
use something that will actually protect your gearbox better than oem.</TD></TR></TABLE>
suggestions?
lol
suggestions?
suggestions?</TD></TR></TABLE>
search in the faq
search in the faq
kazz lsd fluid is EXPENSIVE as hell ($50 bucks a pop and doesnt quite fill up all the way! wat a rip!) but is real thick i like it, but i also have a KAZZ lsd.... jsut Search good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmLove4me »</TD></TR><TR><TD CLASS="quote">kazz lsd fluid is EXPENSIVE as hell ($50 bucks a pop and doesnt quite fill up all the way! wat a rip!) but is real thick i like it, but i also have a KAZZ lsd.... jsut Search good luck
kaaz fluid is designed for clutch type LSDs. The stock ITR diff is a gear type.
A quick search revealed several ITR owners that think that syncromesh is good stuff. Others suggested Motul or just honda OE.
</TD></TR></TABLE>kaaz fluid is designed for clutch type LSDs. The stock ITR diff is a gear type.
so it is imminent to use an aftermarket tranny fluid if going with an aftermarket lsd? or would oem be sufficient on daily driving and weekend track events? Reason i ask is i might be replacing my lsd in near future and final drive.. just like to know what other materials i need before i do the lil project..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">As the tranny gets hotter so does the fluid. I suggest you trying aftermarket fluid. </TD></TR></TABLE> bingo
thats my way of seeing it at least. the fluid "binds" or "seperates" when it gets to a certain temp. try a higher temp fluid like he said above^^^^
A quick search revealed several ITR owners that think that syncromesh is good stuff. Others suggested Motul or just honda OE.</TD></TR></TABLE>
I put some GM Synchromesh w/ Friction Modified in my itr tranny, and it cured my "high-rpm 4th gear grind" for about 2 months. Since then the grind has come back. I think this fluid does work, just not to my tranny's liking.
litterbox
Feb 11, 2005 06:13 PM
