ITR Tranny identification
Old Nov 8, 2004 | 04:08 PM
fridexter's Avatar
Default ITR Tranny identification
Old Nov 8, 2004 | 04:13 PM
B2FiNiTY's Avatar
Default Re: ITR Tranny identification (fridexter)
Just look through the hole where the axles go. If it's see through then it has LSD.
Old Nov 8, 2004 | 04:23 PM
six_speed's Avatar
it should have J4D LSD stamp if it's really from an itr, unless somone removed it/fade but that's not possible since the other person just got it.
Old Nov 8, 2004 | 04:27 PM
B2FiNiTY's Avatar
Does it have a VIN tag on it?
Old Nov 8, 2004 | 04:43 PM
TypeR 599's Avatar
What's up Dan! :heart:
Does the guy have papers from the dealer saying it's an ITR tranny?
Old Nov 8, 2004 | 04:44 PM
B2FiNiTY's Avatar
Do a fatty burn out and see if it leaves TWO tire marks.
Old Nov 8, 2004 | 05:02 PM
gsrmattski
Guest
Posts: n/a
Default Re: ITR Tranny identification (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">Does it have a VIN tag on it? </TD></TR></TABLE>
if its brand new from the dealer, why would it have a VIN tag on it???
Electron Blue Blur's Avatar
IMHO,not a good way to see if it has an LSD,since i can leave 2 black strips with my peg legged S4C.....
Old Nov 8, 2004 | 05:42 PM
all stock's Avatar
Default Re: (fridexter)
someone mentioned you can spin one wheel and the other will spin the opposite way, however i don't know how true/false that is tho.
Old Nov 8, 2004 | 05:43 PM
all stock's Avatar
Default Re: (all stock)
nm, it's false info.
Old Nov 8, 2004 | 05:50 PM
six_speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by all stock &raquo;</TD></TR><TR><TD CLASS="quote">someone mentioned you can spin one wheel and the other will spin the opposite way, however i don't know how true/false that is tho.</TD></TR></TABLE>
in gear then yes, but in nuetral the wheels are independent.
Old Nov 8, 2004 | 11:45 PM
Kicker773's Avatar
Default Re: (Humping_dragon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">
in gear then yes, but in nuetral the wheels are independent.</TD></TR></TABLE>
very good info
Old Nov 9, 2004 | 08:03 AM
JinDIESEL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Humping_dragon &raquo;</TD></TR><TR><TD CLASS="quote">it should have J4D LSD stamp if it's really from an itr, unless somone removed it/fade but that's not possible since the other person just got it.</TD></TR></TABLE>
no that is not tru. the 96-97 itr's do not have this stamp. their tranny's are simply marked "LS1" with a bar code. this is the case for the 96 spec of the ITR because the final drive of the 96 spec compared to the 98 and 01 spec are different. the 96 has a 4.4 final drive while the 98-01 specs have 4.7 i know because ive seen a "96 spec" 1997 jdm itr engine and the tranny shell does not have the LSD J4D stamp on it because of the smaller final drive. and im sure it has LSD because we took off the axles and the holes were see thru
Old Nov 9, 2004 | 09:19 AM
six_speed's Avatar
4.4 fd usdm itr transmission has J4D lsd stamp (i'm not sure of the 96-97 jdm itr spec)
4.7 jdm itr transmission has N3E lsd stamp
Old Nov 9, 2004 | 12:47 PM
Chubz's Avatar
yes it true, and you should look through the axle holes, and if u can see a clear O then ur good but if you see (/) then its not an itr tranny
Old Nov 9, 2004 | 01:03 PM
all stock's Avatar
Default Re: (Chubzilla)
i don't think he wants to remove the axles.
Old Nov 9, 2004 | 01:10 PM
99 TYPE R's Avatar
i bought my itr trans new from dealer with a warranty for 1750.00 mine says j4d lsd, i think an s80 trans is an si tranny, dont get ripped thats all and how much is he sellin it for?
Old Nov 9, 2004 | 01:33 PM
B2FiNiTY's Avatar
burn out
Old Nov 9, 2004 | 01:35 PM
Chubz's Avatar
Default Re: (B2FiNiTY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">burn out </TD></TR></TABLE>
yeah that too..lol
Old Nov 9, 2004 | 01:40 PM
Chubz's Avatar
yeah a one wheeled burnout......and lsd equiped tranny will leave two tires marks behind
Old Nov 9, 2004 | 02:41 PM
mikestypeRR's Avatar
hell yeah i havent dont that they.. but i will cause is sounds fun ... hahahaa
Old Nov 9, 2004 | 03:39 PM
TypeR 599's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fridexter &raquo;</TD></TR><TR><TD CLASS="quote">
Hey Alex!
The guy has papers from the dealer, but it's been over a year. I figure a lot could have happened since then. He's a nice guy though, but not as nice as you.
Was the tranny new when he bought it from the dealer or rebuilt?
If new, you can tell if he tampered with anything inside by looking for some type of sealant(Hondabond) around where the gear housing meets the clutch housing area. OEM is usually very neat around there. if clean, everything inside should be good.
But the burnout is a fun way to check. You dont have to run it to redline to leave marks, just a quick little chirp should leave marks on a white top
what car are you getting??
Old Nov 10, 2004 | 12:23 AM
slammed_93_hatch's Avatar
check out mine for sale (link in my sig)
its the JDM ITR tranny
S13Morgan
Mar 26, 2010 09:18 AM
vtec2nv
Oct 25, 2006 08:32 AM
Fastwhip
Jul 19, 2006 02:39 AM
totally jay
May 6, 2005 12:21 PM
Alpha_GSR
Feb 27, 2003 11:54 AM
