How are you running your downpipe/thermal 3 inch exhaust?
Old Nov 8, 2004 | 03:10 PM
lanojp1's Avatar
Default How are you running your downpipe/thermal 3 inch exhaust?
Ive never really thought about this, but im going to be running a 3 inch downpipe and a 3 inch thermal r&d exhaust...my question is how are you guys running ur setup? Are you just welding a flange onto your downpipe and bolting the midpipe straight to your downpipe? Or is there a need for a test pipe/hi flow cat to bridge the gap between the two?
Old Nov 8, 2004 | 03:44 PM
StolenTeg's Avatar
Default Re: How are you running your downpipe/thermal 3 inch exhaust? (lanojp1)
You will need a flex pipe, Basically the downpipe welded to the flex pipe then a test pipe to the flex pipe then the flange onto the test pipe and connect the test pipe and the thermal together. That how mine is connected...
Old Nov 8, 2004 | 03:53 PM
lanojp1's Avatar
something like this?
http://www.performance-curve.c...D=142
Old Nov 8, 2004 | 04:27 PM
boosted92's Avatar
Default Re: (lanojp1)
Yeppers.
Old Nov 12, 2004 | 09:08 PM
95gsrturbo's Avatar
Default Re: (boosted92)
nice, cheap , and it has nipples!
Marvin1985
Jul 22, 2013 04:06 PM
$amGD3
Feb 9, 2011 11:31 AM
komat
Nov 6, 2009 04:37 PM
Teg4e
May 29, 2002 10:41 AM
