HELP: car starts at 2500 rpms and keeps rising!!
Old Nov 8, 2004 | 03:10 PM
jbell's Avatar
Default HELP: car starts at 2500 rpms and keeps rising!!
we just took off the intake manifold to replace it, the new one didnt fit... so we put the stock b16 one back on. new gaskets on the TB and IM.
it starts at like 2500rpms and just keeps rising.. anyone have ANY ideas on what could be wrong.. we check over all the vaccume lines and such, but nothing looks wrong.
any help is greatly appriciated..
Old Nov 8, 2004 | 03:22 PM
drdisco69's Avatar
Default Re: HELP: car starts at 2500 rpms and keeps rising!! (jbell)
Is the throttle cable too tight, holding the throttle open?
Old Nov 8, 2004 | 03:30 PM
jbell's Avatar
Default Re: HELP: car starts at 2500 rpms and keeps rising!! (drdisco69)
nope. snaps closed to the point where it sits on the little allen screw. even tried adjusting that, nothing.
Old Nov 8, 2004 | 03:48 PM
jbell's Avatar
we tried resetting the ecu... added coolant, adjusting the throttle...
the idle controll has no effect whatsoever.
Old Nov 8, 2004 | 03:53 PM
drdisco69's Avatar
Default Re: (jbell)
I'd look for a leak in the intake manifold then, air is sneaking in somewhere.
jbell's Avatar
Default Re: (drdisco69)
any idea how to do this?
Old Nov 8, 2004 | 04:05 PM
drdisco69's Avatar
Default Re: (jbell)
Spraying carb cleaner around all the gaskets and things can sometimes locate it, or so I hear... Any one else have an idea?
Old Nov 8, 2004 | 04:29 PM
eda6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote">Spraying carb cleaner around all the gaskets and things can sometimes locate it, or so I hear... Any one else have an idea?</TD></TR></TABLE>
I've heard this too. I thought you used starter fluid. When I swapped intake manifolds I sprayed starter fluid around the gaskets. Nothing happened. No leaks for me.
What happens when you find the leak? Do you use starter fluid or carb cleaner?
Old Nov 8, 2004 | 04:38 PM
drdisco69's Avatar
Default Re: (eda6)
I think anything combustable with work, the idea is that when the motor sucks it in, the rpm changes a little, letting you know when you've found it. Starter fluid would work too, but I would stick to carb cleaner, maybe a little safer...
Old Nov 9, 2004 | 06:56 AM
PrettyLude's Avatar
i think ur right drdisco on the first time with the throttle cable being too tight
Old Nov 9, 2004 | 07:07 AM
2SlowDC's Avatar
last time ididnt seat my injectors properly this happend.
Old Nov 9, 2004 | 09:18 AM
drkshdw107's Avatar
yes...carb cleaner is the way to go...if there is a leak you will hear a change in the rpm....its like adding more fuel to the mix and sucking it in right through the leak...i use this method all the time...
Old Nov 9, 2004 | 11:17 AM
b20turbojason's Avatar
Default Re: HELP: car starts at 2500 rpms and keeps rising!! (drkshdw107)
you didn't either clean the gasket off the head good enough or you dont have the bolts tight enough on the intake manifold to the head. this has happened to me before.
Morford3288
Engine Management and Tuning
Jul 14, 2013 08:17 AM
1989sircrx
10
Mar 27, 2010 04:26 PM
si90rex
Jun 24, 2007 07:12 PM
1baddturbosi
Mar 19, 2007 04:06 PM
vc
Aug 22, 2006 02:19 PM
