ECU ERROR 41..HELP!
Old Nov 8, 2004 | 09:51 AM
integra95gsr's Avatar
Default ECU ERROR 41..HELP!
so my CEL came on after i put on my exhaust.. catco highflow.. its a 95 gsr, and is obd0..the error is " 41 Primary oxygen sensor heater ", can someone please get this annoying yellow CEL off my beautiful dash..hehe thanks..
Old Nov 8, 2004 | 11:28 AM
JimBlake's Avatar
Default Re: ECU ERROR 41..HELP! (integra95gsr)
Unplug the sensor, find the 2 same-colored wires from the sensor. Measure resistance between them, it should be between 10 & 40 ohms. Neither one of these wires should have continuity to ground. If it's bad for either of these, get a new sensor.
If the sensor is OK, then you've got a wiring problem in the car. But I guess it's most likely a bad sensor.
Old Nov 8, 2004 | 12:06 PM
debogsr's Avatar
Default Re: ECU ERROR 41..HELP! (JimBlake)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JimBlake &raquo;</TD></TR><TR><TD CLASS="quote"> But I guess it's most likely a bad sensor.
Happened to me not to long ago. I found alot of threads on this topic. Serach under "Primary oxygen sensor heater" and alot of stuff should come up.
luispequeno
Dec 13, 2010 09:16 AM
all-mtr-teg
Oct 2, 2007 11:59 AM
breathinez
Aug 18, 2004 09:20 AM
Snydog0510
Jun 16, 2003 08:52 PM
