cat/test pipe
Old Nov 8, 2004 | 09:17 AM
volkdlr's Avatar
Default cat/test pipe
how much difference will a hiflow cat make in terms of horsepower on a typical B16 with header/intake/exhaust? I'm guessing 1-2 hp at most ?
how much more hp will it gain if it was a test pipe on the same set up?
Old Nov 8, 2004 | 09:20 AM
nighttrain33's Avatar
Default Re: cat/test pipe (volkdlr)
Usually they make about the same horsepower difference. I think that my friend (B16 w/ i/h/e) made more power from the high-flow cat than his test pipe. Probably from the loss of backpressure I am guessing.
-Shane
Old Nov 11, 2004 | 12:09 AM
ptoledo's Avatar
I would also like to find out how much power i will gain from a test pipe.
Right now im running b18C1 w/ vtec control, Intake, 4-1 header, 2 1/4 piping w/ stock muffler.
HEHEHE!!! this weekend ill have installed:
blox type A cams
supertech valve springs & retainers
golden eagle cam gears
blox intake manifold
Modified by 98sjGSr at 10:25 AM 11/11/2004
Modified by aLLMotorDB8 at 8:18 AM 11/4/2005
Old Nov 11, 2004 | 03:44 AM
ek99's Avatar
Default Re: cat/test pipe (98sjGSr)
You will never loose power by adding a test pipe. You might loose some torque under 3k but after that, you'll gain about 4-5 hp. Why do most people go open header at the track? Because when you take off, you usually rev high enough to where you don't want any back pressure. Backpressure is good for mostly low rpm, where your engine doesn't make much power. This is more true of the torque-less b16 than the b18.
Old Nov 11, 2004 | 04:00 AM
HatchEh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by volkdlr &raquo;</TD></TR><TR><TD CLASS="quote">how much difference will a hiflow cat make in terms of horsepower on a typical B16 with header/intake/exhaust? I'm guessing 1-2 hp at most ?
how much more hp will it gain if it was a test pipe on the same set up? </TD></TR></TABLE>
Dude that high flow will add a good 5-8 hp. On my stock d15b7 i threw an AEM V2 (really works in high rpm) and an Apex-i catback system... once i added the high-flow cat...i REALLY noticed a difference in torque(less) and hp(more). lets just say i went from chirping 2nd to really squealing 2nd. (n yes in high rpm more hp means more spin..not ONLY torque)
Old Nov 11, 2004 | 06:47 AM
McNizzle's Avatar
Default Re: cat/test pipe (HatchEh2)
since you live in CA i would go with the cat so you dont fail emissions and usually in most cases, cats make your exhaust sound less raspy than if you have a test pipe. either route you go you will be satisfied with I guess.....but its not like your adding a turbo or anything, gains are very minimal.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HatchEh2 &raquo;</TD></TR><TR><TD CLASS="quote">
and i assume this was never even dynoed, am i right? and what is the point of wheels spinning? you know that means you are getting less traction meaning you are moving slower right?
Old Nov 11, 2004 | 07:32 AM
Deemeetree's Avatar
Electrician
Default Re: cat/test pipe (Chris M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris M &raquo;</TD></TR><TR><TD CLASS="quote">
and i assume this was never even dynoed, am i right? and what is the point of wheels spinning? you know that means you are getting less traction meaning you are moving slower right?</TD></TR></TABLE>
I guess he thinks more power = more tire spin which = accelerating faster? *shrugs shoulders*
Both will yield power, but the test pipe might have a bit of an increase. The thing you come in conflict with is emissions and your exhaust being REALLY loud.
Old Nov 11, 2004 | 07:46 AM
HatchEh2's Avatar
Default Re: cat/test pipe (Dimi)
...NO, the fact that they spin easier means clearly u have more power...i said nothing about accelerating fast by spinning wheels ********. i know my damn physics. Now that you have more power, u can maybe possibly get LSD and put it to work or learn to take off quicker without burning out to ACCELERATE better..again, "NOW THAT YOU HAVE THE POWER"
07 4DR Si
Honda Civic (2006 - 2015)
Jun 27, 2007 08:08 PM
rivoe302er
Jan 13, 2007 07:01 PM
JDMxNguyeN
Mar 20, 2006 01:04 PM
smash fascism
23
May 26, 2005 07:26 AM
JDM00SI
Feb 20, 2005 06:42 PM
