Ignition cut out
Old Nov 7, 2004 | 09:10 PM
windg@t's Avatar
Default Ignition cut out
Hi need help
This only occurs ocasionally. While you drive the car seems to loose all spark, as if the whole elctrical system died, but the radie, fan, indicators all seems to work, however, now warnning lights come one, and ther is no spark top the distribitor it seems. The engine will crank, but wont start. When you tutrn the ignition key of and on again it will start en then ther is spark.
'What good it be. have checked all the electrical connections, and all seems fine. Need help
Thanks
Old Nov 8, 2004 | 05:31 AM
EE_Chris's Avatar
Default Re: Ignition cut out (windg@t)
There was a recall on some 96-00 Civics for the ignition key being defective - did you get it, or is this car 'new' to you? If its 'new' to you, contact the sellers to see about the recall.
Old Nov 8, 2004 | 06:20 AM
drdisco69's Avatar
Default Re: Ignition cut out (EE_Chris)
Also what kind of car is this?
Old Nov 8, 2004 | 09:12 PM
windg@t's Avatar
Default Re: Ignition cut out (drdisco69)
Its a 1986 Honda Ballade (I am from South Africa) 1500. I think its the ignition switch, beacause last night it did it again, all accesories are wotking only the ignition is of and when it cuts out and you turn the key to start and back to the on position, the dashboard lights light up and the car starts.
Thanks for the reply
Morag
May 21, 2017 10:12 AM
Tank_EM2
Honda Civic (2001 - 2005)
Aug 22, 2014 08:31 AM
prelude504
Sep 7, 2009 03:19 PM
rizzoTK
Aug 29, 2005 02:35 PM
wizzards581
12
Dec 11, 2003 06:25 PM
