CTR pistons in ITR ?'s
Old Nov 7, 2004 | 06:57 PM
xtcat9k's Avatar
Default CTR pistons in ITR ?'s
I searched and did not find much info about any ITR owners using CTR pistons in there cars is there any one who has done this in there ITR and is there any valve Clarence issues i want to bump up my compression more just thought that it would be a rought to go any INFO would be great thanks. Also what is your compression?
Old Nov 7, 2004 | 07:01 PM
BlueR's Avatar
Default Re: CTR pistons in ITR ?'s (xtcat9k)
you should have no valve clearance issues if you have a stock head that has not been milled and depending the advancement of the cam gears...
compression will be ~12.2:1 with B18c5 block and PR3 head with stock headgasket
Modified by BlueR at 11:24 PM 11/7/2004
Old Nov 7, 2004 | 07:04 PM
xtcat9k's Avatar
Default Re: CTR pistons in ITR ?'s (BlueR)
right now i have spoon 2 layer head gasket at skunk2 flat high comp. valves will the stock boar work or do i have to get the .25 over boar
Old Nov 7, 2004 | 07:23 PM
BlueR's Avatar
the spoon HG is not necessary, stock would be ideal
.25 overbore would depend on the condition of your cylinder walls
Old Nov 7, 2004 | 08:03 PM
irev210's Avatar
if it is the first time tearin down the motor, you will prolly be okay with STD bore
not a bad way to bump the compression, but make sure you have the fuel to support that increased compression
Old Nov 7, 2004 | 08:06 PM
Madspeed's Avatar
Default Re: CTR pistons in ITR ?'s (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">
not a bad way to bump the compression, but make sure you have the fuel to support that increased compression</TD></TR></TABLE>
are you refering to fuel pump or injector???
Old Nov 7, 2004 | 09:09 PM
BlueR's Avatar
Default Re: CTR pistons in ITR ?'s (Madspeed)
fuel injector
Old Nov 7, 2004 | 10:35 PM
strepto's Avatar
Id say he was reffering to the actual fuel, and not a specific fuelpart. He'd need premium unleaded to go with that. I run my post 12:1s on 98Oct.
Old Nov 8, 2004 | 01:35 AM
b18c-rDC2's Avatar
Default Re: CTR pistons in ITR ?'s (strepto)
You can run the 2 layer HG with the ctr pistons and you will not have any problems, compression will just be slightly higher than if you were running the oem head gasket. I had ctr pisons with a pr3 head milled 20k and had no problems whatsoever, though I was employing a J&S as a cheap insurance policy...g luck
Old Nov 8, 2004 | 02:08 AM
Pondus's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xtcat9k &raquo;</TD></TR><TR><TD CLASS="quote">right now i have spoon 2 layer head gasket at skunk2 flat high comp. valves will the stock boar work or do i have to get the .25 over boar</TD></TR></TABLE>
You are aware of the fact that the CTR pistons in addition to a Spoon headgasket and high comp. valves will bump you up to a little over 13:1 CR? So what octane gas do you plan on using? One reason for the increase in CR is the fact that the CTR pistons have a compression height of 30.25mm while the stock ITR pistons is at 30mm.
Valve clearance should always be checked by claying the engine when using different pistons, you will also know for sure how much the cam gears can be advanced or retarded without running into problems.
B18C block/PR3 head stock bore = 12.58
.25 over = 12.65
Add to this ~ 0.25 for the gasket and about the same for the valves and you have gone beyond 13:1.
Look at this if you don't beleive me : https://honda-tech.com/zerothread?id=717928
Old Nov 8, 2004 | 05:21 AM
xtcat9k's Avatar
Default Re: CTR pistons in ITR ?'s (Pondus)
I was thinking about getting ride of the spoon head gasket and keeping the valves i am running hondata right now and also i just put in a new short block with like 8k on it if i get the standard boar do i have to bring the block to get honed or anything?
I was thinking i want to make around 12.5 comp the ctr pistions and high comp valves should get me there?
Old Nov 9, 2004 | 12:37 AM
Pondus's Avatar
CTR pistons alone in an otherwise stock B18C5 engine will get you the CR i posted, i.e. slightky over 12.5:1.
Your valves will bump it up to ~ 12.8.
Old Nov 9, 2004 | 08:43 AM
Madspeed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pondus &raquo;</TD></TR><TR><TD CLASS="quote">CTR pistons alone in an otherwise stock B18C5 engine will get you the CR i posted, i.e. slightky over 12.5:1.
Your valves will bump it up to ~ 12.8.</TD></TR></TABLE>
with this set up (CTR pistons Stock ITR engine) pump gas should be fine ??? (93oct) with a 12.5:1 compression. And does anyone have any dyno info on this that shows the difference in stock and CTR pistons?......okay ill search now.....lol
not to jack the thread but im looking into doing the same to my engine.
Old Nov 9, 2004 | 08:53 AM
BlueR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Madspeed &raquo;</TD></TR><TR><TD CLASS="quote">
not to jack the thread but im looking into doing the same to my engine. </TD></TR></TABLE>
93 octane will work if your tuner dials back the timing
Old Nov 9, 2004 | 11:26 AM
typer_801's Avatar
12.5:1 seems kinda high...Sgt used to quote the CR as 11.6:1 - Stock ITR w/CTR pistons.
Old Nov 9, 2004 | 12:41 PM
Chubz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by strepto &raquo;</TD></TR><TR><TD CLASS="quote">Id say he was reffering to the actual fuel, and not a specific fuelpart. He'd need premium unleaded to go with that. I run my post 12:1s on 98Oct.</TD></TR></TABLE>
not true 93 or higher is fine. I ran a 12:1 setup for over a year on 93 octane never had any detonation problems what so ever
Old Nov 9, 2004 | 12:42 PM
Chubz's Avatar
Its more like 12:1 -12:3:1, CTR pistons in a GSR motor is 12:5:1
Old Nov 9, 2004 | 12:45 PM
Chubz's Avatar
Default Re: CTR pistons in ITR ?'s (typer_801)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by typer_801 &raquo;</TD></TR><TR><TD CLASS="quote">12.5:1 seems kinda high...Sgt used to quote the CR as 11.6:1 - Stock ITR w/CTR pistons.
its over 12, he never said it being 11:6:1, because id nail my compression tester needle well past the 300psi mark, 11:5:1, would net you 240-260 psi
Old Nov 9, 2004 | 01:31 PM
AW's Avatar
AW
If CTR pistons are make too much with 2 layer head gasket, would the JDM ITR pistons be a better combination. I need to rebuild my motor this winter and was considering CTR pistons or going with JDM ITR pistons and a thinner head gasket. I only want to get near 11.5:1?
LvN
Mar 17, 2006 09:38 AM
KRiS1
19
Aug 14, 2003 04:39 PM
b18c-rDC2
Mar 12, 2003 01:27 PM
EFing8
10
Dec 14, 2002 04:00 PM
Ruby Civic
Sep 7, 2002 11:40 AM
