removing a antenna???
Old Nov 7, 2004 | 03:08 PM
CaptinMcnut's Avatar
Default removing a antenna???
how do i remaove the antenna in a 94 del sol any help is appericateds
Old Nov 7, 2004 | 03:17 PM
suspendedHatch's Avatar
Default Re: removing a antenna??? (Darren90teg)
if its the same as the 92 civic then just take it off, unplug it at your radio, then slide the whole mess out. you need one of those funny shaped tools. is it called torx head?
its easy just figure it out as you go.
Old Nov 7, 2004 | 04:09 PM
hctjohnson's Avatar
yes its a torx bit, no its not too hard but it can be time consuming
Old Nov 7, 2004 | 04:23 PM
civictildeath's Avatar
Default Re: removing a antenna??? (hctjohnson)
if you are putting another one in make sure you tie a string to end inside car BEFORE you pull it up or you will never get it back in there
Old Nov 9, 2004 | 05:51 AM
Default Re: removing a antenna??? (civictildeath)
thanks for input thanks for that tip civictildeath
Old Nov 9, 2004 | 06:38 AM
TouringAccord's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">if you are putting another one in make sure you tie a string to end inside car BEFORE you pull it up or you will never get it back in there</TD></TR></TABLE>
You can get it back in there it'll just take you a little longer with a lot more wiggling and playing with the cable to get it through the "A" pillar.
w8
Jul 31, 2006 04:19 PM
yellowmonkeyboy
Feb 14, 2006 02:22 AM
nrgone
Jun 17, 2005 07:17 PM
hondaracing1
May 12, 2005 05:37 PM
THE GAME IS THICK
Mar 7, 2005 11:13 AM
