HID
I just want to buy a HID to my 04 SIR, I don't know which one you guys used currently, and which factory is good? and how much it will cost mostly? I heard the cheapest HID is made in Taiwan, is that good?
A reputable place to get HID kits from is http://www.xenondepot.com/. They sell a Philips HID retrofit kit and they also make their own HID kit for most cars. The Philips HID kit is the one to get. They're more expensive (they're $550 for 4300K - $650 for 6000K) but they're high quality and will last you a long time. (Most OEM HID's use Philips bulbs/ballast)
And stay away from the cheaper taiwan no-name stuff. The quality isn't there and you might have to keep replacing ballasts and/or bulbs. Also don't go above 6000K cause the higher you go, the less light you'll actually get and you'll also have the ricer "blue" lights. 4300K is the brightest and is used by OEM's.
More info can be found here:
http://www.hidplanet.com/forums/
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k-cerez »</TD></TR><TR><TD CLASS="quote">i happen to know a guy that works at a high end auto body shop and i got mine out of a Lexus GS 430 for cheap so maybe look into a body shop
Is the auto body place located in So. Cal? I might be interested in getting the same thing. Also did you retrofit a projector into your stock headlights? Or just modify the clips to hold the new HID's?
</TD></TR></TABLE>Is the auto body place located in So. Cal? I might be interested in getting the same thing. Also did you retrofit a projector into your stock headlights? Or just modify the clips to hold the new HID's?
How's the glare on the stock headlight housing? I've always wanted to get HID's but i'm worried about killing someone with the glare.
I'm also tempted to do a projector retrofit, but i'm worried about damaging the headlight. (I'm good with basic bolt on's, but doing a retrofit requires a tad bit more skill
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pr0ns74r »</TD></TR><TR><TD CLASS="quote">How's the glare on the stock headlight housing? I've always wanted to get HID's but i'm worried about killing someone with the glare.
) </TD></TR></TABLE>
I know a guy who had a dc5 that had retro HID. glare all over the place. now he got JDM HID which shine nicely.
) </TD></TR></TABLE>I know a guy who had a dc5 that had retro HID. glare all over the place. now he got JDM HID which shine nicely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznbo1626 »</TD></TR><TR><TD CLASS="quote">
Just to make sure I'm reading this right, he placed OEM HID projector housings (TL, TSX, etc.) into stock RSX headlight housings and had glare? I'd be surprised. I thought that was the cleanest application possible.
</TD></TR></TABLE>Just to make sure I'm reading this right, he placed OEM HID projector housings (TL, TSX, etc.) into stock RSX headlight housings and had glare? I'd be surprised. I thought that was the cleanest application possible.
Declectic
Honda Civic (2006 - 2015)
14
Aug 23, 2006 03:42 PM
