How to wire relay to disable ignition sensor on alarm?
Old Dec 23, 2001 | 10:35 PM
Tommy_Gunns's Avatar
Default How to wire relay to disable ignition sensor on alarm?
I'm trying to install a car starter. How do I go about disabling an alarm so the car starter can function without the alarm going off? On the supplied instructions, it says something about using a relay to accomplish this...does anybody have a detailed wiring diagram of how I should hook up a relay to do this?
Thanks
Old Dec 23, 2001 | 10:55 PM
infinkc's Avatar
Default Re: How to wire relay to disable ignition sensor on alarm? (Tommy_Gunns)
if im reading your question right, you are trying to add remote start?? and want to disable your ignition sensor so when you activate your remote start the alarm will not go off? all you have to do is tap off any of the wires that provide a 12v signal when the remote start is activated, connect that lead to 85 on a relay, 86 on the relay will go to ground( if your remote start provides a negative signal when activated, hook 85 to the neg signal, and 86 to 12v. Now cut your alarm ignition wire. The side going to the key connect to 30, and the side going to the alarm connect to 87a. There should be one unused terminal on the relay 87. Hope this helps.
Old Dec 23, 2001 | 11:36 PM
Default Re: How to wire relay to disable ignition sensor on alarm? (infinkc)
Thanks alot...so I should connect the accessory (12v when car is on or a wire off of the starter brain) wire to lead 85 on the relay, cut the alarm ignition sensor wire and place the relay in between....right?
iliv2xlr8
Audio / Security / Video
Nov 30, 2008 11:16 AM
kleen98accord
15
Aug 25, 2008 12:18 PM
cyvic
Aug 3, 2003 06:51 PM
MurphDog74
Mar 26, 2002 11:33 PM
Weston
Jan 30, 2002 04:01 PM
