Can someone check my list?
I plan on having a B20 Turbo for daily driving, anywhere from 10-16psi, I made a list of things I might have to do to the block but after reading more searched posts I think I have too much things for just a motor pushing 10-16psi. I had added it all up money wise and it came up to be about $10,000, too much for me. Here is my list..
B20 Motor
LS Transmission
LS Intake Manifold
P75 LS ECU
LS ECU w/OBDII-OBDI Conversion Harness
Hondata ECU Chip
“B” Series Engine Mounts
Axels
Turbo Timer
Boost Controller
Garrett T3/T04E 60 Trim
Intercooler
Intercooler Piping
Waste gate
Manifold
Down pipe
Blow off Valve
Pistons- Weisco Forged Pistons and Rings
Rods- Eagle Rods
Turbo Cams- Crower Cams
Cam Gears- AEM Adjustable Cam Gears
Fuel Rail- AEM
RC 550cc fuel injectors
Fuel pump-Walbro 255lph Kit
Fuel pressure regulator
Spark Plugs
Wires
Aluminum Flywheel
Stage 3 Clutch Kit
Balanced Block
Blueprinted Block
Eagle Forged Crank
Valve Springs
Retainers
Sleeves
Port and Polish Head
If anyone wants to take their time and read over this and let me know what I need and dont need for a 10-16psi daily driven B20, non-crvtec, id appreciate it, thank you.
B20 Motor
LS Transmission
LS Intake Manifold
P75 LS ECU
Hondata ECU Chip
Axels
Turbo Timer
Boost Controller
Intercooler
Intercooler Piping
Waste gate
Manifold
Down pipe
Blow off Valve
Rods- Eagle Rods
Fuel Rail- AEM
Spark Plugs
Wires
Aluminum Flywheel
Stage 3 Clutch Kit
Balanced Block
Blueprinted Block
Eagle Forged Crank
Valve Springs
Retainers
Sleeves
nice stuff but like jeiden said... dont need the crank. the stock one is fine or if you want to go with a lighter and cheaper one put a LS crank in it. alittle bit lighter than the B20 cank.
Block girdle would be good but I would recomend getting the machine shop to do it since most of them out there need a certian amount of clearences on both ends.
I would also get bigger injectors you will max out the 550's with that much boost. I would get 750's to be on the safe side
well im look maybe for about 300+, do you think I wall need all of this? Because 10k is way outta my hands, I figured if I sleeved it, it would be ok to run 10 psi. Im looking for a setup for about 5k or less. But still reaching the HP number on the B20. O ya and I have no idea what a girlde is, sorry. And yes to anyone who asks I have searched already, and thats how I got most of my list, but right now the search isnt working.
streetracer6rpt
Jun 20, 2007 06:41 AM
streetracer6rpt
Jun 18, 2007 07:12 PM
