Compression ratio on B18a1..
Old Nov 7, 2004 | 10:59 AM
tRex99's Avatar
Default Compression ratio on B18a1..
I have aB18a from a 90 teg. I took 2 rounds on C/R and first run i use 2 differnt tester..i used one on cylinder 1 and 2 and 1 on 3 and 4...the second run i use the one from 3 and 4 on all 4 again...
1. 200 2. 190 3. 189 4. 185
2nd run
1. 205 2. 200 3. 197 4. 194
Does this sound about right i mean i know they arent all the same but they didnt leak when i let them sit either so thats good atleast...well then again the cant anyway from the guage...
Old Nov 7, 2004 | 11:10 AM
JustinG60's Avatar
Default Re: Compression ratio on B18a1.. (tRex99)
alot better than me! but from friends asking what normal is i hear that's right on
mines
1. 75
2. 75
3. 95
4. 115
hahahahaha thinking the head has bad valves though cause the same thing happened to my rabbit... but my rabbit atleast ran...
Old Nov 7, 2004 | 12:26 PM
J337_UNIT's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRex99 &raquo;</TD></TR><TR><TD CLASS="quote"> I have aB18a from a 90 teg. I took 2 rounds on C/R and first run i use 2 differnt tester..i used one on cylinder 1 and 2 and 1 on 3 and 4...the second run i use the one from 3 and 4 on all 4 again...
2nd run
that is not compression ratio, that is just called a compression test, its not testing for compression ratio, rather how much PSI each cyclendar can hold. you can use the number to help figure out if there are any significant problems with the motor, and it could help you determine compression ratio but you have to put those numbers into some kind of math equation.
your numbers are fine tho, i have a b18b and im at like 185 apprx straight across.
Old Nov 7, 2004 | 12:34 PM
tRex99's Avatar
Default Re: Compression ratio on B18a1.. (J337_UNIT)
Yea i know my bad...i know the equation but its a pain in the *** and takes me forever, my buddies a math genius so he showed me ...anyway yea i just wanted to know the psi i should be around...i cant get my car to run and nothing adds up anymore...the only thing that could be wrong is something with the dizzy...
Yemdogg
Sep 5, 2006 09:34 AM
a2dadamm
Jan 6, 2006 08:20 PM
pnoi_01dc2r
Aug 1, 2005 03:18 PM
kwik93si
Mar 20, 2004 06:37 PM
HondaRacer32
Jan 3, 2004 06:29 PM
