compression
Old Jan 6, 2006 | 04:16 PM
a2dadamm's Avatar
Default compression
what is a good compression rate or an average rate. iim new to compression i wanna find out more about it .. i wanna do a turbo setup on my 90 teg.. and i hear alot about having good compression....thanx for any help.
Old Jan 6, 2006 | 05:49 PM
watsvtecEK's Avatar
Default Re: compression (a2dadamm)
i think like high 180's -210, anywere around there is good, the higher the bertter, and what matters most is that the compression of each cylnder is close of the same as the others.
Old Jan 6, 2006 | 06:39 PM
Racermech's Avatar
Default Re: compression (D 2da A9)
What motor do you have???
LS is 195 max. GSR is 210 max
Old Jan 6, 2006 | 06:42 PM
Moshimoto racing's Avatar
..........<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D 2da A9 &raquo;</TD></TR><TR><TD CLASS="quote">i think like high 180's -210, anywere around there is good, the higher the bertter, and what matters most is that the compression of each cylnder is close of the same as the others.</TD></TR></TABLE>
yep
Old Jan 6, 2006 | 06:43 PM
omiehomie's Avatar
Default Re: compression (Racermech)
i thought 240 was the max and not 210 on a b series motor? can some one verify this?
Old Jan 6, 2006 | 06:48 PM
Uncle Ben's's Avatar
Cogent Argument Enthusiast
Default Re: compression (omiehomie)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by omiehomie &raquo;</TD></TR><TR><TD CLASS="quote">i thought 240 was the max and not 210 on a b series motor? can some one verify this? </TD></TR></TABLE>
only thing i can verify is that my LS had 150 compression across all four when i tested it amost 2 years and 33k ago. runs perfect.
Old Jan 6, 2006 | 07:07 PM
a2dadamm's Avatar
its a stock ls
Old Jan 6, 2006 | 07:30 PM
viet_boi_racin's Avatar
i believe 195 is max for a LS motor.. but the main thing to look for is the numbers are not TOOO low.. or There isnt TOO much variation between the cylinders.
Old Jan 6, 2006 | 07:41 PM
omiehomie's Avatar
Default Re: compression (viet_boi_racin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by viet_boi_racin &raquo;</TD></TR><TR><TD CLASS="quote">i believe 195 is max for a LS motor.. but the main thing to look for is the numbers are not TOOO low.. or There isnt TOO much variation between the cylinders. </TD></TR></TABLE>
good stuff
Old Jan 6, 2006 | 08:20 PM
watsvtecEK's Avatar
i pulled 200-205 psi each cyl, on my 93 ls. i dont know if the tester i used was accurate, but the important thing was they were all even.
SilverPanda
Oct 9, 2007 10:25 PM
I-4
Jun 10, 2007 08:57 AM
1.8T_EG
Jul 6, 2004 08:27 AM
b18coupe
Mar 10, 2004 04:33 AM
DOHCarp
Sep 11, 2003 07:10 PM
