200HP SOHC
Old Nov 7, 2004 | 10:59 AM
BDTURBO's Avatar
Default 200HP SOHC
So I have a Greddy kit on my 95 SOHC (7psi). Just wondering what I needed to do to get around 200hp out of this puppy. Dont really know where I stand until I get her dynoed. Feeback appreciated!
Old Nov 7, 2004 | 11:00 AM
Pfieff's Avatar
~10psi
Old Nov 7, 2004 | 11:03 AM
BDTURBO's Avatar
Default Re: (Pfieffdog)
nice.........but will that hold up on stock internals or will i need to build the motor?
Old Nov 7, 2004 | 11:07 AM
Pfieff's Avatar
stock internals
Old Nov 7, 2004 | 11:21 AM
ek9 ferio's Avatar
Default Re: (BDTURBO)
It's all in the TUNING bro, tuning is the KEY. I'm getting ready to boost my d16y7 as well 9-10 psi. I recommend running atleast Hondata s100 and get it dyno-tuned, just make sure u upgrade all your fuel system. i.e. fuel injectors & walbro fuel pump.
Old Nov 7, 2004 | 12:34 PM
blackeg's Avatar
Default Re: (ek9 ferio)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek9 ferio &raquo;</TD></TR><TR><TD CLASS="quote">It's all in the TUNING bro, tuning is the KEY. I'm getting ready to boost my d16y7 as well 9-10 psi. I recommend running atleast Hondata s100 and get it dyno-tuned, just make sure u upgrade all your fuel system. i.e. fuel injectors & walbro fuel pump.</TD></TR></TABLE>
doesnt have to be hondata, but yea its all in the tune.
Old Nov 7, 2004 | 12:53 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (blackeg)
**** hondata.....go uberdata . tuning is the answer , seems like you have the tools to achieve it . might need some injectors tho.
Old Nov 7, 2004 | 05:44 PM
BDTURBO's Avatar
Default Re: (OnePointSicks)
but if i have the blue box i dont have to tune correct?
Old Nov 7, 2004 | 05:46 PM
ATS*Mark's Avatar
OG triple OG
no , because the blue box is meant for hte stock 5.5 psi.....ditch that and go uberdata . then tune it. you wont be disapointed by the switch , i know i wasnt.
Old Nov 7, 2004 | 05:49 PM
MooreBoost's Avatar
Agreed. Get yourself some good tuning, and you can make 200 all day.
Old Nov 7, 2004 | 06:23 PM
tmg's Avatar
tmg
Default Re: 200HP SOHC (BDTURBO)
197bhp at the wheels, this is what i ran in my old d16y8 setup, which i no longer have:
greddy td04 16g (95 obd 1 civic kit) without black box
12.1:1 fuel pressure
98 prelude injectors ~ 180cc
12lbs boost
apexi vtec/fuel controller
advanced timing ~ 2deg.
60mm tanabe g power exhaust
trust fmic
that's roughly about it. exactly what the others said, tune and dyno.
Old Nov 8, 2004 | 08:20 AM
BDTURBO's Avatar
Default Re: 200HP SOHC (themi6group)
thnaks for all the input...sounds good guys...do I need to get a wideband O2, sensor if I run Ubertdata? where do I get the burner and chips from...how much?
Old Nov 8, 2004 | 09:20 AM
Johnyquest's Avatar
Uberdata and a tune you pull out your *** can make 200whp at 10psi. I did it. Twice
Matt
Old Nov 8, 2004 | 09:56 AM
junkyard racer's Avatar
Default Re: 200HP SOHC (Johnyquest)
if you want that **** uberd' let me know.
-frank
210 can be safe with some good uberdata.
-im in jacksonville, so you can drive down here, and have it chipped within a matter of a few hours.
a good tune will require a dyno or a wideband. i can hook you up with a decent base map...
http://www.homemadeturbo.com/f...29002
Old Nov 8, 2004 | 11:00 AM
99B16Si's Avatar
Default Re: 200HP SOHC (junkyard racer)
Bone stock D16z6 w/ 180k miles
Greddy turbo kit
DSM 450's
Uberdata
10psi
Old Nov 8, 2004 | 12:20 PM
Timmay's Avatar
Default Re: 200HP SOHC (99B16Si)
10 psi and a v-afc should get you 200 whp
my buddy had a 99 hatch with the stock d16y7 DX motor, with a 92-96 greddy kit, d16z6 intake manifold 2.5" exhaust and some v-afc tuning made 193 whp on 9-10 lbs
Old Nov 8, 2004 | 01:22 PM
beerbongskickass's Avatar
Default Re: 200HP SOHC (Timmay)
I'd really look into getting your ECU chipped if you can. Uberdata is the way to go these days.
Old Nov 8, 2004 | 05:16 PM
BDTURBO's Avatar
Default Re: 200HP SOHC (beerbongskickass)
whats a liter of cola.....LOL...I love that movie.....u guys have been so helpful..thanks for everything. I'll keep you in mind when I save up some money to chip my ECU.
Old Nov 8, 2004 | 06:04 PM
dornon13's Avatar
good luck bro im in the same boat...hey guys what would be a better turbo choice for a 200whp goal...
Old Nov 8, 2004 | 07:48 PM
norcalcrx's Avatar
Default Re: 200HP SOHC (dornon13)
Its all in the tuning and the fuel system. I know this from experience.
Old Nov 9, 2004 | 07:44 AM
pollito's Avatar
Maybe this will give some insight. Your goals are very achievable.
http://www.turbod16.com/viewtopic.php?t=4140
Old Nov 9, 2004 | 08:44 AM
BDTURBO's Avatar
Default Re: (pollito)
nice number!!!!!!!!!!!
Old Nov 9, 2004 | 09:46 AM
boostincoupe's Avatar
From: Destroying turbo ITR motors in Minneapolis, MN, U.S.A.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by OnePointSicks &raquo;</TD></TR><TR><TD CLASS="quote">no , because the blue box is meant for hte stock 5.5 psi.</TD></TR></TABLE>
Then why am I running 8 psi on it with no problems?
Old Nov 9, 2004 | 09:56 AM
dornon13's Avatar
Default Re: (boostincoupe)
does anyone run a sc34 on their D i am considering running one at about 7-10psi but i am concerned about the spool what do you spool at if you run one
Old Nov 9, 2004 | 09:59 AM
dornon13's Avatar
Default Re: (dornon13)
wait is a sc32 bigger than a sc50?
