My clock has died?
Old Nov 7, 2004 | 08:16 AM
milton's Avatar
Default My clock has died?
The stereo died, the gauges lights are weak now? I believe its a shortage is there a way to fix this? If so please help thanks
Old Nov 7, 2004 | 08:18 AM
NightRiderS2K's Avatar
In-N-Out Burger
Default Re: My clock has died? (milton)
Does your car still crank or even start?
Why don't you check all your fuses instead of freaking out
Old Nov 7, 2004 | 08:22 AM
milton's Avatar
everything works just the lights seem to be weaker Checked every single fuse none blown
Old Nov 7, 2004 | 08:33 AM
Deluzional's Avatar
Have you checked the fuse under your hood?
Old Nov 7, 2004 | 08:39 AM
milton's Avatar
Default Re: My clock has died? (Deluzional)
done that, every fuse in the bottom steering wheel checked hood checked? is there any more fuses?
Old Nov 7, 2004 | 08:40 AM
sykotic's Avatar
check your under hood fuse box, I had this problem and the fuse was in the under hood fuse box, it was a 7.5A fuse called Back Up, let me know if this was your problem as well.
Old Nov 7, 2004 | 09:09 AM
milton's Avatar
Default Re: My clock has died? (sykotic)
it still works, i replaced every fuse to new ones
Old Nov 7, 2004 | 07:11 PM
milton's Avatar
help em
Old Nov 7, 2004 | 07:12 PM
wanna b R's Avatar
battery?
Old Nov 7, 2004 | 07:23 PM
black_cap's Avatar
Default Re: My clock has died? (wanna b R)
sounds like your battery is getting weak, time for a replacement.
Old Nov 7, 2004 | 08:35 PM
source's Avatar
Default Re: My clock has died? (black_cap)
Clean your battery terminals with a wire brush...some baking soda and water helps too. worked for me. Usually dim lights are a grounding issue.
good luck
Old Nov 7, 2004 | 10:33 PM
eg6T's Avatar
Default Re: My clock has died? (source)
if it was the battery it wouldnt crank too well and the battery doesnt run the car.all the battery does is start the car and make use of the stereo and crap when the car is off.what powers all that stuff when you are driving? the alternator...if you are driving and the lights get dim and the radio goes off...its your alternator...i assume
Old Nov 7, 2004 | 10:37 PM
milton's Avatar
Default Re: My clock has died? (eg6T)
could it be from a system i had hooked up? i had a amp hooked up under my seat and i took it off last week then after that i had these problems, what could have happened?
Old Nov 7, 2004 | 11:05 PM
eg6T's Avatar
well yes that could be.
pcrodrig
Dec 20, 2007 04:42 PM
y2kferari
Mar 28, 2007 04:46 PM
merch1
Mar 6, 2005 11:07 AM
Jmorin
Sep 24, 2003 09:55 AM
