Input shaft bearing?
Old Nov 7, 2004 | 07:54 AM
CR-VTEC EG's Avatar
Default Input shaft bearing?
What kind of effects would i be looking at if my input shaft bearing went bad? I can't shift my car if i'm high in the rpm range, it works fine for daily driving but i can't shift when under hard exceleration. Also, if i'm cruising at 60mph, i can't downshift into 4th, it comes out of 5th fine but won't go into 4th, if i force it, it makes a bad grinding noise, it almost seems like i'm shifting without the clutch.
Any help would be awesome, i don't know if it could be the throwout bearing, input shaft bearing, or maybe a spring in the clutch disc that went bad?
please help
steve
Old Nov 7, 2004 | 08:14 AM
CR-VTEC EG's Avatar
Default Re: Input shaft bearing? (CR-VTEC EG)
up
Old Nov 7, 2004 | 08:19 AM
mmuller's Avatar
Mad Scientist
fi your isb. is bad i would make noise as you drive.
if the tranny grinds when shifting in the upper rpms, but its fine down low then it could be your synchros
Old Nov 7, 2004 | 08:26 AM
drdisco69's Avatar
Default Re: Input shaft bearing? (mmuller)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mmuller &raquo;</TD></TR><TR><TD CLASS="quote">fi your isb. is bad i would make noise as you drive.</TD></TR></TABLE>
I just get a funny image in my head when I think of that.
Old Nov 7, 2004 | 09:05 AM
Denny Crane's Avatar
Default Re: Input shaft bearing? (drdisco69)
Bad throwout bearing: makes noise only if the clutch pedal is depressed.
Bad input shaft bearing: makes noise when clutch is released with the engine running. Does not have to be in any gear.
Bad output shaft bearing: makes noise only when the car is in motion. Same for diff carrier bearings.
Bad synchro: makes noise only when attempting to engage a gear. Rarely rpm related. You do have at least a bad 4th gear synchro. Check your clutch adjustment for the higher rpm shift probs in the remaining gears.
Bad clutch spring: doesn't necessarily make a noise, but could make clutch pedal appear to jam, depending how it fails.
Old Nov 7, 2004 | 10:00 AM
zad5's Avatar
bad clutch spring hella hard to put it into gear almost impossible it would start getting worse and worst until u just cand do it my springs fell out of the clutch.
Old Nov 7, 2004 | 01:24 PM
CR-VTEC EG's Avatar
Default Re: (zad5)
thanks for the help guys, sounds like my clutch is shot...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zad5 &raquo;</TD></TR><TR><TD CLASS="quote">bad clutch spring hella hard to put it into gear almost impossible it would start getting worse and worst until u just cand do it my springs fell out of the clutch.</TD></TR></TABLE>
sounds like my problem, it's getting harder and harder to shift gears
thanks again for all the help guys
steve
MySelfAffliction
Jun 26, 2019 06:59 PM
rugimpy
Nov 18, 2010 08:18 AM
HomicidalHatchBack
10
Nov 11, 2006 05:47 PM
uNF$@#!
May 13, 2005 07:59 AM
BI8B
Sep 16, 2003 06:14 AM
