new swap
i just did a new swap a b16a2 motor into a 93 hatch back, and if u look at my other post i am having problems with high idling and high fuel usage, but this morning i just got some time to read the CEL codes and here's what i got,,, code # 1, # 3 # 7 # 10 # 14 and # 16,, i was shock because the motor came out my friend's 95 ingetra friday and was running prefect , so i am wondering if its the ecu, i am using a p75 the same one he was using,,. any info on this. thanks
code 1=oxygen sensor #1
code 3=map sensor
code 7=throttle position sensor
code 10=intake air temperature sensor
code14=idle air control valve
code16=fuel injectors
hope this helps
code 3=map sensor
hope this helps
LoseRPunKx182
Aug 25, 2005 08:53 AM
JDMs1eeper
12
Jun 22, 2004 05:15 PM
foesicks
Jun 4, 2003 09:47 AM
