Help W/ ARP Head Studs
Old Nov 7, 2004 | 06:35 AM
greddytunedhatch's Avatar
Default Help W/ ARP Head Studs
I got a Y8 motor that would have been done and put in this weekend, if it weren't for my head studs. For some reason, all bolts except one stick up out of the block way more than needed (about and inch) so my head cannot be tightened down. One bolt is fine, and that hole in the block measures down about a 1/4 inch further than the rest of the holes. I don't understand!!
Does ANYONE have head studs (ARP or stock) for a Y8 motor they can measure the length for me? Is it correct that one hole in my block is deeper than the others?
thanks, I really need an answer today!
Old Nov 7, 2004 | 08:16 AM
Matty.'s Avatar
Default Re: Help W/ ARP Head Studs (greddytunedhatch)
check that you have the correct part number. Your threads may need cleaning. Get a tap and some tap fluid and try again.
Old Nov 7, 2004 | 08:48 AM
EJ8 D15Y8's Avatar
You got the wrong part #
Y8's and y7's have 1 different size head bolt. Dizzy/Firewall side head bolt in the corner.
All the rest are the same but that one.
Old Nov 7, 2004 | 03:05 PM
Default Re: (EJ8 D15Y8)
thanks for the help
CyberC1ren
Dec 2, 2013 10:30 AM
marcsed6
Jan 3, 2010 12:34 PM
flashedDc5
Oct 23, 2006 05:46 PM
shermanyang
Mar 29, 2003 11:02 PM
LsTurbo91
Jul 10, 2002 08:58 PM
