Throttle Body Gasket. Can I just silicone the outside edge?
I ******* searched today, 4 stores. Not one place had a ******* gasket for a Crx
I dunno, think other years will fit to correct? But whatever. Ive got some spare blue gasket silicone type **** here and I want to know if I can use that only?
Also Ive never seen a t/b gasket before, is it just a square going only around the outside with the bolt holes cut out or does it go into all the little contours n ****?
What would I have to silicone
Thanks
Thanks
like I said Ive never seen a t/b gasket for a Honda
Does it just go over the outside or does it cover everything and just the intake bore is cut out? Or are all these little grooves cut out.....
Know what Im saying
Know what Im saying
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ]{iwi »</TD></TR><TR><TD CLASS="quote">just go get some gasket material and make it useself </TD></TR></TABLE>
You can do that or you can use hi-temp rtv silicone gasket maker (hondabond).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1 Cam Wonder »</TD></TR><TR><TD CLASS="quote">Or are all these little grooves cut out.....</TD></TR></TABLE>
The grooves are cutout.
You have to get it at the dealer.
I would not recomend honda bond or anything like that. The MAP passage needs to be sealed right and I don't think you can do it with H-B type of product.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs »</TD></TR><TR><TD CLASS="quote">You have to get it at the dealer.
</TD></TR></TABLE> No you don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs »</TD></TR><TR><TD CLASS="quote">I would not recomend honda bond or anything like that. The MAP passage needs to be sealed right and I don't think you can do it with H-B type of product.</TD></TR></TABLE> If you have a good vacuum hose and did a good job of sealing the tb then the MAP passage will be sealed right. I used RTV silicone on my tb. No leaks. It's less than $5 try it.
i went to advance auto yesturday to pick up a tb gasket for my civic. i gotta switch tps' soon and i heard i should change it. they had to order it but it should be in today. final price? $2.10
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eda6 »</TD></TR><TR><TD CLASS="quote">
it's moronic to use RTV when a paper gasket that costs maybe a couple of bucks more will do the job right.
Get the damn gasket. Your Honda dealer sells it for sure, it will work the way it was designed to work and that's the end of it.
</TD></TR></TABLE>it's moronic to use RTV when a paper gasket that costs maybe a couple of bucks more will do the job right.
ok, i'll get a gasket. I have an aftermarket tb. Didn't know if the honda gasket would work. I'll get some gasket material and fix it.
civic_driver
Sep 25, 2005 11:51 PM
